Any news on this?
My 2010 is in need of rear rotors. Also, what do you mean by "machining"? Are you talking thickness?
Ok... after some help from my friends ... here goes.... rear non vented rotors from a circa 2002-2006 Ford Focus are a close match. i say close because from measurements given of this stock rotor that sells at NAPA for $14.50, they need minimal machining to match. Also, rear vented rotors from a 86-88 Ford T-bird turbo coupe fit, if machined. Harder though, due to the vented rotor - they would have to machine the whole back disc off - one person verified this method and did it. Wish i could have marked the blog, but i know what i read.
I have yet to physically verify this for myself, but i am pulling the rear wheels today to check the brake pads because i rode home last nite WITH the parking brake on, only 10 miles, but thats another story - i have the capability to machine and drill the rotors if this works... and for $15, im thinking its worth a try. And if it does ....
should be problem solved. NOW - IF - i cannot machine these, i will take to one of the machine shops i deal with at work, and im sure with the machining it could only cost me around $50....so add it up ... $15 x 2 + $50 = WAAAY ahead of HDs price and probably a better product as i will have them drill and slot the rotors also.
Take it with a grain of salt - this to me is all STILL a project that i have not completed, but i know im on the right track. Check it out for yer selves. Heres to experimenting!!
:LordHelp:
