The 2012 triglides have the worst rear brake stopping issues . Performance Machine has a stage II , 11” rotor and 4 piston combo replacement . Has anyone used this system ? As anything other than throwing out a anker out has got to be better.
With the non-ABS tri glides the rear brake is just there to scrub off speed andamuse you not for an emergency..
With my X 2011 Triglide if I had to make a quick stop I would pull up the bars as hard as I could and with authority yell whoa….. that seem to work?
Only reason you pulled up to the bars , is because your shorts filled up with shit ….…:AGGHH:
