2014 tri_glide cats
Oct 17, 2013
16
1
Carlsbad,NM,USA
What is gained by removing your cats on the 2014 tri-glide? With the water cooled exhaust the heat doesn't appear to be a big problem. I am a first time Harley owner ex rider getting back into the game clapping. Learning all over again. Help!!! :confused:
Removing the cat would improve exhaust flow. The less restricted the more air/fuel you can push through the motor, assumption being more power.
The most help comes from the loss of a bunch of radiated heat from the collector area in the header. This is felt mainly by the passenger setting over, & behind it. Improved flow helps some also.
Thanks everyone. Is the TQ gain by removing the cats worth the cost of replacing the header pipes if you don't have a problem with the heat. I don't have a problem with the heat now but might in the middle of the summer months with our temps.
The best thing you can do right now is ride the snot out of it, especially if the heat isn't bothering you. Since the 2014 does have some significant changes you want to make sure your warranty stays in tact.
I loaded my 13 on my trailer and cut cat out then took to local muffler shop and had true duels made...100.00 bucks and put RC mufflers. No heat. I now have stage one. Runs great and pulls hard.IMG_20130712_172128_605.jpg IMG_20130712_172110_415.jpg
Its my understanding thats a high flow cat, theres probably more restriction at the baffles. The radiant heat can be a problem on very hot days in the summer. On those days we start early and end early when traveling. I do know that Harley Davidson has reps in every area. If you have a warranty claim thats significant, that rep will come to your dealer in some cases and examine your trike before the repairs are approved.Dont take my word for it, ask your service desk at your dealer. If theres alot of mods, be prepared to pay for it yourself if it effects your problem.
zigzag3227
