vtx 1800 5th gear power
My '07 w/ Roadsmith was also essentially a 4 speed. Need to have the beast running between 3 & 4 k in all gears above first. 3200 rpm seemed best for mine.
I put on a 2 into 1 Roadburner pipe and a Mach 2 intake & filter. Made a big difference. I can run and maintain 60 -65 mph in 5th now. (It's pretty flat in FLA remember) Before the conversion I needed to be 70 -75 mph in 5th to be able to hold speed. If RPMs dropped below 4k I had to drop a hole. It will even recover now without shudder or other complaints from down around 2800 rpms. Need to be take it easy on the throttle and bring it up a slowly, though. Or drop a hole. Hammer it and grin like a loony while it settles you back in the seat and stop at the next station for more motion lotion 'cause you're not going to get very far when you hammer it.
I rode for several weeks w/o a tach. Had a H*** of a time with the shuddering and bumping etc. The calibration of my ears from my previous rides for getting the shifts right (up and down) just wasn't there and I couldn't get it right. Tach was good investment for me. Keep it between 3 & 4 K in 2,3 4 and above 4 in 5th.
I've had no problem with the rev limits in 5th. I've been up to 110 and had more throttle left than nerve at the point and got off of it.
guys his complaint is that he can not go fast enough, because he is geared wrong. in 5th full throttle on the rev limiter not going 80 mph. he needs to go back to the dealer
I'm with you! Seems to me that the dealer / installer has got his f/d ratio very wrong. I would be interested to read of the outcome. Baz.
Nailed it right on the head.
No trouble getting over 70mph as long as you increase slowly or drop down to 4th and accelerate.
As for the ratios........I called them and they said it was the best set up. They had tried all the rest.
Sadly though my gas mileage sucks, 22.5 was the best all weekend for 1000 miles.
Call them Baz and talk with them. Very interested to find out what they say to you for the different ratios they have experimented with.
Roadsmith
3744 Schueneman Road
White Bear Lake, MN
(800) 331-0705
(651) 777-7774
No, Meredog's problem is he feels his bike isn't strong enough to pull a trailer because it feels weak pulling in 5th at low RPM's. He's used to the original bike traveling at highway speeds in 5th gear. Yes, the gear ratios are different, I believe, but not enough to make a big difference... Now, just leave it in 4th at highway speeds, and only shift into 5th if you are greatly exceeding, say, 65- 70 mph. It will have enough power, for higher speeds as well... as long as the RPM are high enough.
REOFL has the problem of low speed at high RPMs. My guess is somethings slipping... and yes, he should take it back to the dealor... this just doesn't sound right. I've ran equipment and big trucks for more than 35 years... I'll tell you, almost every engine I've ran will shudder if you try to push a low speed in a high gear (with low RPM)... it's called "lugging" the engine. If your engine doesn't do it, it's a very well engineered engine, but doing this is not "healthy" for any engine. JMHO Chumbly-;)
Chumbly I was responding to REOFL's post not Meredogs. He not suffering from lugging. He is on the rev limiter (5700 RPM) in high gear (5th) and only going a little over 70. That's what I read and understood in both of his posts. Your right the clutch could be slipping or he is just geared to low. Not being there riding the bike it's hard to say. I would think that much slipping he would notice, but hard to say.
Went back to the ROADSMITH installer and they had me check the gearing (count of one wheel turn gave be about 3.5 drive shaft revolutions 3.55 seems to be what RoadSmith has determined to be the best ratio through trial and error during design).
I took it back out on a test drive with a GPS to check the speedo and the speedo read about 5 mph slower than the GPS {in 1st 3000 rpm gave me 24 mph, 2nd 3000 rpm gave me 35 mph, 3rd 3000 rpm gave me 45 mph, 4th 3000 rpm gave me 54 mph and 5th 3000 rpm gave me 64 mph.} So guess the combination of smaller wheels 18" to 16" and final drive 3.09 to 3.55 plus the 5 mph speedo error puts me in a safe zone for cursing on the highway (couldn't get to a highway to check out 70 mph, will try this weekend); definitely lost some top end, but never go much over 75 anyway.
Looks like I just lacked experience/ the new feel of a trike and the fact that the VTX F model isn't a good trike candidate, due to the compromising of some Honda design parameters.
I do experience the "shudder" (shakes the hell out of the handle bars) below about 2500 rpm that goes away above 3000 rpm. May try a heavier duty clutch, I think I read somewhere on the posts that some of the shudder may be from the extra weight and the clutch not engaging smoothly, anyone have any experience here?
Definitely need the 6% rake kit as the trike wobbles at slow speeds, below 30-45 mph, then steadies out and drive smoothly above that.
There should have been a "speedo-healer" with the kit to correct the speedometer.
The shudder has nothing to do with the clutch. It's the engine not up to the right RPMs.
Here's where I got my 6* rake.
xf6 custom design llc, parts and accessories for valkyrie motorcycles and vtx motorcycle
I used to get the vibration in my handle bars (VTX 1300R) as well but adding the 6 degree rake kit from VTXTreme has taken the low speed wobble and just about all vibration out of the equation. Smokin Joe turned me on to VTXTreme. Nice guy (Daryl Hokensburg) owns the shop and he does nice work and will hold your hand or your installers hand throughout the install process. Check em out.
Check out the sponser Adventure MotorSports of this forum for your rake. Kit. Bazooka will set you up.
TifCHN
