Throttle Lock
With your customization of the back side and using your finger, does that mean you are able to rotate the fat part down because you are taking the tension off? If so that's not a bad idea. I've not put one on because I wasn't sure I could get it out of the way quickly. That would sure do the trick.ThumbUp
yes it can work that way as well as flipping it over the grip backward, its easier to flip it backward though.
If you have fringed grips it will also not get hung up on the seams.
Be sure you are using it correctly. Thumb lever down is ON. but you can roll thru it. Thumb lever up is OFF and throttle should work freely. Do not lube it. It holds the throttle using friction. the nut and spring provide the friction.
JStogner
