Stallion Pedal Raise Switch Question
I had to replace my switches for both the pedals and air compressor. Also, you need to lube the screw drives once in a while as they sometimes bind up.
What are switch #'s and where can I get them?
Where are they located? Under toggle?
How do I access screw drives?
Thanks & Blessings
Thanks & Blessings
You can purchase the rocker switches from Amazon. I got lighted ones several years ago. I don't remember the numbers, but they're not hard to find. Just search Momentary Rocker Switch. I got Kering's. You can try this number, but I got them in 2021.
  • ASIN ‏ : B08L6CJ9F6
The screw drives are on top of the pedals. you can see the screws and can spray some spray lube on them. someone may have jammed them up and you may have to free them if they're stuck.
Rick
dyno56ca
