Stallion brake pedal.
Nov 10, 2009
8
Mass
Has anyone heard of a modification to put the brake pedal on the same side as the gas pedal? I am interested in buying a Stallion but I cannot have controls on the left foot. Any ideas? Thanks, Bob from Mass.
If you are looking to modify the brake, you may be able to get someone to add one above the gas peddel on that flat area. You may be able to get someone to put on a hand break control, because the break is so sensitive it should work good on a conversion. Either way good luck, you will need someone who is a full custom shop. The people who do it normaly would be hesitant to go that far out on the limb unless they are confident it will work perfectly.
Roger71!!
