My pedal rise swith doesn't work. Checked fuses, OK. Lights (same fuse) work. Any ideas?
What are switch #'s and where can I get them?I had to replace my switches for both the pedals and air compressor. Also, you need to lube the screw drives once in a while as they sometimes bind up.
You can purchase the rocker switches from Amazon. I got lighted ones several years ago. I don't remember the numbers, but they're not hard to find. Just search Momentary Rocker Switch. I got Kering's. You can try this number, but I got them in 2021.What are switch #'s and where can I get them?
Where are they located? Under toggle?
How do I access screw drives?
Thanks & Blessings
