Stallion Parts & Maintenance Reference
Re: Parts & Maintenance Reference
tmigala
I had discount tire mount the tire, I took the wheel off and put the wheel back on.
had lots of fun taking the wheel off cause the axle was way to tight, the bearings ID was smaller than the axle OD.
thanks to Kevin at TBMS that problem was taken care of.
also had lots of fun putting the wheel back on. one of the bolts that go into the fork tubes (down tubes) needs to be modified, only one, you will have no problems putting the first one in but when you go to do the 2nd one you will have lots of fun unless you modify it, then it is easy.
I also have a complete list of the tools needed, some metric and some ASE.
New issue: Shifter Cable
On our trip out west, left TX and crossed over into NM. At the Visitor's Center parking lot, could not turn the key. Couldn't reach TMS and was starting to get nervous. My husband rocked the Stallion a bit and we were able to start it. Went on to Deming, NM. Next morning, same problem.
Called TMS and they said it was not reading that it was in Park. We went by the Ford dealer who had no interest in helping us. Drove to Lordsburg, NM where the folks at Smith Ford were great.
Biggest issue is communicating to a Ford dealer that it's a TMS warranty and they need to call in for authorization and instructions. The service tech said he knew what to do and didn't need them telling him what to do. I tried in various ways to explain that it was about getting paid and not voiding my warranty but no luck. Wish TMS could communicate about their product to the Ford dealer system. They want the dealers to call them but the Ford service guys don't want to wait for the busy signal to clear or to wait for Nick or Kevin to be free to speak to them. Once they finally get to talk, all goes well and the work gets done.
Now, back to my problem. The shifter cable simply needed adjustment to shift into Park and then back to the appropriate gears. Had to have it readjusted at a dealer in Calif but then we were good to go. Just a heads up if your key freezes up and nothing happens. Rock the Stallion till it settles into Park and then head to the shop for an adjustment.
Stallion Girl
Stallion Girl
A similar problem can be a lock out on the shifter due to a problem with the brake sensor. To solve this problem, you will need a flat head screw driver to pop off the cap on the face of the shifter and then push the flat metal plate and that will allow you to shift out of park. I had to do that once and it is a great thing to know when you are stuck by the side of the road!
Or just lift up the hood. find the button, depress it then shift transmission selector out of Park (preferably Neutral...so you can start the beast)
tmigala
Silverdevil. Can you give us a blow by blow on this project when you have time. I do not need it now but I'm sure I will in the future. Thanks
Re: Parts & Maintenance Reference-Trunk latch
I have found that if you put both hands on each end of the trunk on the top and just push straight down as if you were pushing through the trunk, it closes very nicely. I had the same issue when I first got my stallion.
tmigala
Please advise list of tools needed and parts numbers for the bearing, if you have them).
the tools needed to change out the front tire on the Stallion
go to page 49 in the little Stallion Manual and follow the steps up to step #5 on page 52.
the following is some of the steps from the manual WITH the TOOLS added.
REMOVING YOUR FRONT WHEEL
ON PAGE 49 AND 50
ITEM # 5 ON PAGE 50
REMOVE LOWER SHOCK BOLTS
( ALLEN HEAD SCREWS)
8mm ALLEN WRENCH
ITEM # 6 ON PAGE 50
LOOSEN THE FOUR PINCH BOLTS
3/16" ALLEN WRENCH ON BOLTS
7/16" WRENCH ON NUTS
ITEM # 9 ON PAGE 50
LOOSEN CALIPER SLIDE BOLTS
22mm SOCKET OR 7/8" SOCKET
ITEM # 10 ON PAGE 50
REMOVE THE BRAKE CALIPER STRUT.
14mm NUTS ON BOTH ENDS.
7/32" BOLT ON FORK TUBE END. (ALLEN HEAD)
ITEM # 11 1/2 (NOT LISTED)
TO REMOVE THE FRAME THAT HOLDS
THE BRAKE CALIPER USE A
7/32" ALLEN WRENCH
ITEM # 12 SLIDE THE AXLE OUT
30mm WRENCH OR SOCKET
THE SWING ARM THAT THE AXLE GOES THRU
AT THE BOTTOM OF THE FORK TUBE USE
6mm ALLEN ON THE BOLT AND USE
17mm OR 11/16" WRENCH ON THE NUT
TOOLS NEEDED
6mm, 8mm, 3/16, 7/32" ALLEN WRENCH
14mm, 17mm, 7/16" WRENCH (REGULAR)
IN PLACE OF THE 17mm YOU CAN USE
A 11/16" WRENCH
30mm SOCKET OR WRENCH FOR AXLE NUTS
22mm OR 7/8" SOCKET (MUST BE SOCKET) # 9
hope this answers your questions on what tools are needed
I did not change out the bearings, the wheel bearings just need lube added, a good wheel bearing grease.
a test for your STALLION dash panel
A SIMPLE TEST FOR THE GAGES AND THE LIGHTS IN THE DASH PANEL
PRESS THE TRIP BUTTON (CHANGES TOTAL MILES TO TRIP MILES) AND HOLD,
THEN TURN THE KEY TO ON
THE DISPLAY IN MILES METER SPELLS "tESt", THE T'S ARE LOWER CASE
PRESS AND RELEASE THE TRIP BUTTON THE 1ST TIME, ALL FOUR GAGES
WILL GO TO FULL ON AND THEN BACK TO FULL OFF AND THEN THE TEMP
AND GAS GAGE WILL DISPLAY THE ACTUAL TEMP AND ACTUAL GAS IN TANK.
PRESS AND RELEASE THE TRIP BUTTON THE 2ND TIME AND THE "MILES METER"
WILL DISPLAY ALL "8's"
PRESS AND RELEASE THE 3RD TIME AND ALL THE LIGHTS WILL COME ON.
IF YOU HAD THE LIST OF DIAGNOSTIC CODES PRESSING THE TRIP BUTTON
FURTHER WILL GIVE YOU LOTS MORE CODES, WITHOUT THE LIST IT IS NO
GOOD UNLESS "TBMS' IS ASKING YOU TO DO IT.
OK, The problem is the rings that are at the bottom of my roll bar. Each one has 3 little wings that hold it tight. There is a wing broken off of each ring. Don't know why or when. The way they are now, water can go right thru behind the trunk. Can they be replaced? I'm sure, but how? Where would I get replacements, Any Suggestions?
Can I suggest silicone the area around the hole to seal it and seat the rings so they do not move. No reason to ever take that area apart unless it is to replace the roll bar. I would just seal it up with clear.
we have the same problem with broken lock rings on roll bar. not only do they tip up and look like crap-wife has hers tied down with pipe cleaners- if its broke ,fix it. older models we have seen have metal rings-not plastic. will be trying to order these when i get back home. looks like a fairly good job of fixin unless roll bar just slips out.
The stallion holds exactly 4 quarts of oil.
The rear brakes when purchased from an auto parts store are off of a 07' Ford 500.
Re: Parts & Maintenance Reference-Tire pressure
The Owner's Manual says to maintain proper air pressure but I can't find anywhere in there where it says what that is supposed to be. Can anyone advise? Thanks!
Stallion Girl
42 psi front, 24 psi rear. it is located on the VIN sticker on the front frame under top triple tree
mORNING GUYS AND GALS,
i HAVE A BAD THROTTLE CABLE ON MY STALLION.....IT BROKE THE PLASTIC CONNECTOR AT THE TOP OF MOTOR....
DOES ANYONE KNOW WHAT THE PART NUMBER IS FOR REPLACEMENT?
ODDOMAN
EFFINGHAM, SC # 667:no::no::no:
ODDOMAN
I think your going to have to call Stallion on that.
To the Stallion owners, I found this lift searching the internet. It's available through Northern Tool. It has a lift capacity of 2000 lbs. I thought it might be the answer for servicing my YET to arrive Stallion, like changing the oil, tires, exhaust work and so on. Since I hold the comments and opinions of this forum in such high esteem, would anyone care comment. (I hope the attachment photo displays correctly...)
Daydreamer
Daydreamer
I like that. Looks like it might just work.
Daydreamer
It appears the minimum height on the lift you found is 3 9/16 in. I have a 2008and jack I bought has min 3.5 in height and it is too tall for my Stallion. Be sure to check this out befpre you buy
Good catch. The Stallion is low
GWRRA 164
I did not realize that the Stallion has such low ground clearance. < 3.5", now that's low. May have to consider backing it on a pair of shallow ramps first to raise its backend before placing the lift in position. I suppose it's wishful thinking to believe that the 2011 models will have a higher ground clearance than the earlier models. Thanks for your input...
Daydreamer
the ground clearance is just a little better than 3.5", it is 4.5" plus you can air up the rear suspension and raise it a little more, you have no problem to air it up to 100 lbs, don't ride it there but you can air it up to there.
I have seen them raise a Stallion up with a large pallet jack at TBMS, I have seen Kevin the lead mech do it.
you can get ramps at wal-mart and they are easy to back up on, I have 2 sets of ramps and after backing up on one set I jack up the front end and put another ramp under the front wheel. now no problem changing oil and filter using a creeper.
Silverdevil,
Thanks for your input. Maybe it won't be necessary to use ramps with this lift. I surely hope so... I see that you use ramps exclusively to service your Stallion. I'm not sure if I'll buy the lift... Just something to occupy my mind while I'm waiting for my Stallion to arrive. I have a similar lift that I used to service my Gold Wing. It's a Craftsman and it sure made the servicing alot easier. I like the idea of the lifts over the ramps, as it just makes the job easier, especially servicing the tires or wheels.
Daydreamer
a jack on either side of the hitch will raise up the rear end to get the rear tires off, same as a car.
the front wheel is a bit different, I did a write up on this site as to how to take the tire off and what tools to use, some are metric and some are inches. it is in this thread and message #68.
one listed above is an ATV lift that will go about 28"+ and cost less than $300 http://www.northerntool.com/shop/tools/product_200422212_200422212&issearch=176373
this one is a pallet jack and will go about 7" higher than the ATV lift (High Lifting Hydraulic Pallet Truck — 2000-Lb. Capacity | High Lift Pallet Trucks | Northern Tool + Equipment) will raise 2000lbs just over 35".
this one is less than $600.
now of course the legs will be in the way for some things.
so far with a floor jack, jack stands and ramps I have been able to do everything I need to do but it would be nice to get it more than 1' off the ground sometimes which is about what I get with what I have.
It looks like a pallet jack. Would you be able to get it high enough to do anything?
Bill,
As Silverdevil stated, it's an ATV lift vs a pallet lift, although it sort of looks like a pallet lift. Although it's rated the same as the pallet lift mentioned, it appears to be much more sturdy at the arms as well as the base. For the price, (1/2 the price of the mentioned pallet lift), the choice to me is rather clear which one I'd choose. The fact that it's max. lift range is about 6"-7" shorter, is not all that important. One still can lie on a creeper to do much of the undercarriage work and the use of a small stool to work on the wheels, brakes, etc.
If nothing hangs lower than the Stallion's frame, i.e. the exhausted system for instance, than one should be able to use the lift without wooded blocks. The other concern was the ground clearance of the Stallion, but if it's higher than 3 1/2+", then it should work.
As I mentioned ramps and support jacks will do the trick as well. Having a functional lift such as the ATV Lift, just makes the job a bit easier, IMHO.ThumbUp
Daydreamer
The link give a better image of it and see how it works. It is rated at 2000 lbs. The Stallion weight is 1736lbs Curb weight and GVWR at 2400 IMHO if planning to lift the whole thing up... too close for comfort to maxing the lift out unless using jack stands and pulling the lift out. Rate it at 2500 lbs and I’d consider it.
If your only lifting one end or the other it might work.
Personally I drive the front wheel up on a ramp and use two scissor jacks in the back to get it up on jack stands. Extra scissor jack was 5$ at Pick and Pull.
The first time I tried this the front wheel just pushed the ramp on the cement floor. That was funny... I put a rubber matt under the ramp to keep it from sliding.
I measured the distance from the outside behind the step pad to the frame on the other side and the distance is 43 inches.
the arms or forks on the ATV lift if I read the specs correct is 28 1/2" so it is way to short.
the arms or forks on the pallet jack listed above is 44 7/8" long so it will work.
I did watch Kevin, the lead mech at TBMS lift my Stallion with a pallet jack so he could pull the front wheel assy to change the sealed bearings where one was no longer sealed. this was a regular hand operated pallet jack that may lift maybe 6"
to me this means that the ATV jack at $300 will not work and
the pallet jack for $570 plus shipping will work. I have a northern tool store about 30 miles from here so they MAY order one with no rush and save me the shipping cost, don't know for sure.
there is another lift that will lift 3000 lbs to a height of just over 31" with 43" long forks for $970 Vestil Tote Lifter &#151; Hand Pump, 3,000-Lb. Capacity, Model# L-270-HD | High Lift Pallet Trucks | Northern Tool + Equipment
Roger71!!
