Anyone know of a Solex carb parts supplier in the UK. I am looking for a Solex 34 pict 3 Air correction jet with emulsion tube size 55
Not located in the UK, but ships there I do believe. You'll have to copy/paste as I couldn't get a link to post:
vwparts.aircooled.net
Hope that helps...
Not heard anything as yet. I have however found another car so I have spares there if I need them. Cheers
it drop in revs then putters out unless you catch it i am guessing that one of the internal fuel ways is still blocked.............s**t !
The symptom you describe sounds like the idle control solenoid could be bad.
The solenoid is a small cylindrical shaped piece, with one power wire in, located on the lower left (throttle cable) side. It threads into the carb.
Easy fix, so don't scrap the carb until you check the solenoid!
