Road Smith Rear Tire Pressure
Tire story
Just had a customer in today that changed his rear tires at 70,000 miles (205-70-15). He had been running 20 psi since new.
Had a customer several years ago that had to change her rear tires at 25,000 miles because the centers wore down to the wear bars. She had always run 26 psi.
6 pounds = 45,000 miles........:AGGHH:
Several factors influence tire wear:
1. trike wheelbase & width
2. Average load
3. Area of primary riding. For me, lots of twisties; not sweepers and straights.
4. Road surface - smooth asphalt vs. chip and seal like Arkansas uses a lot.
5. Temperature - hot climates vs. cool climates
6. Riding style - cruising easy or running hard.
7. Tire brand and specs.
Other than these reasons it's pretty cut and dry. :Shrug:
I ran the rear tires in my wifes Stallion at 24lbs the whole 8 years they were on her trike. They had 85k and were still at 5/32 tread depth about 2/32 above the wear bar. Changed the tires due to age. Yes air pressure does make a difference
RS recommends 26 to 30, anyone ever tried 32 or 35? If so, downside, rough ride, upside better mpg? Opinions invited.
Doubt that 2 or 5 lbs will make that much difference, but just my opinion.
From what you posted first, the difference could be as much as 9 lbs:AGGHH:
but just my opinion:Coffee:
Why would one want to run more than what's recommended by the manufacturer:Shrug:
Because mfg., particularly autos, recommend the pressure that gives the best ride. I usually run 5# higher for better wear and performance on curvy roads on my vehicles. For instance, my Suburban says 30# in a tire rated for 44# max. I use 35# so I'm not riding on a marshmallow. 5# makes quite a difference.
So, changing trike rear tire pressures to suit the owner's needs are common. (NOTE: all pressures remain within tire mfg. specs!)
I get your point dawg, from 26 to 35 is 9 lbs, but from 30 to 35 is only 5, but putting that aside, seems your point is pretty much consensus of comments here which is what I was looking for. I was looking maybe to increase my mpg by increasing the rear tire psi, but that may be a faulty thought process. It's just one of those things, if it ain't broke don't fix it. I appreciate all the comments.
Because of 2 big sails(fenders)sticking out in the wind now, even raising tire pressure will not help the MPG enough to suffer the harsher ride and the much lower tire mileage.
Good observation, the thing is obviously not aerodynamic. I've often thought why not curved fenders? Oh well, that discussion for another time. I have my psi at 30, so I think it's back to 26.
Mine is not a road smith. I use 15# in my road star/champion running 205 60 15s. The load capacity of just one tire is more than enough for my trike with 2up. I have asked those riding behind me in the twisties to look for tire roll. They all said they couldn't keep up enough to look. I have not rolled one off yet and wear is even at 20,000 mi. When I got back from Maggie Valley, it turned colder in MI before I checked air pressure. 13# right side and 11# left. We have severe crowning in Mi roads so I run 2 # less on the high side. Eleven pounds still worked great at Maggie Valley.
Rear tire size on my GW RS is 255 55 16, a larger tire to be sure than what you're running, but 15 lbs, with two up, sounds very low, and I'll bet it gives you a smooth ride. I was at the Maggie rally, didn't meet you but seems I recall the beard and mustache. I didn't stay at the Best Western, but with friends in Maggie just down the street. What is that 15 lbs giving you in mpg?
Dragon warrior
