bikerbillone
3000+ Posts
RS recommends 26 to 30, anyone ever tried 32 or 35? If so, downside, rough ride, upside better mpg? Opinions invited.
Just had a customer in today that changed his rear tires at 70,000 miles (205-70-15). He had been running 20 psi since new.
Had a customer several years ago that had to change her rear tires at 25,000 miles because the centers wore down to the wear bars. She had always run 26 psi.
6 pounds = 45,000 miles........:AGGHH:
Doubt that 2 or 5 lbs will make that much difference, but just my opinion.
From what you posted first, the difference could be as much as 9 lbs:AGGHH:
but just my opinion:Coffee:
Why would one want to run more than what's recommended by the manufacturer:Shrug:
Because of 2 big sails(fenders)sticking out in the wind now, even raising tire pressure will not help the MPG enough to suffer the harsher ride and the much lower tire mileage.I get your point dawg, from 26 to 35 is 9 lbs, but from 30 to 35 is only 5, but putting that aside, seems your point is pretty much consensus of comments here which is what I was looking for. I was looking maybe to increase my mpg by increasing the rear tire psi, but that may be a faulty thought process. It's just one of those things, if it ain't broke don't fix it. I appreciate all the comments.
