Road Glide 3 - Is this normal?
JerseyGirlRider
20+ Posts
Jan 9, 2024
20
38
Silver Spring, MD
Monique
Please forgive if this is a silly question, but this is my first motorcycle. After I ride, I pull into our garage (enclosed) and turn off the bike. I find that I have had to start leaving the windows cracked, because the gasoline/exhaust smell lingers for quite a long time. For example, I rode my bike and came home a but before 5 pm. And my garage still smells like a mix of gasoline and exhaust. Is that normal? Thanks.
My '21 Freewheeler does something similar. I like to close the garage up if I just got back from a chilly ride because it warms it up in there nicely. I rather like the smell. :) I mean, I don't know how STRONG your RG3's odor is, but it's probably normal especially considering it's new and burning off junk from the manufacturing processes and also your not used to it yet.
My Tri Glide, does the same thing….(actually most bikes that I’ve had have done That in my garage) specially, on a cool day and if you garages fairly air tight, it’ll be more pronounced.. Also I’ve noticed if the gas tank is well below a quarter tank it’ll be more pronounced..
I think this is an interesting post. I personally have not experienced this occurrence myself. I like the "close the garage" and keep the heat in concept. I personally do leave the garage door open when I pull in for probably 20 to 30 minutes while the bike cools down, something I have always done with every bike we have had. I have no gas smell ever, no exhaust smell either. I do lean towards agreeing that a new bike (with that new bike smell) could be a minute burning off the newness. My 17 FW does not leave any odors ...
Girlrider, Are you possibly refilling the tank at the end of each ride? That could account for the gasoline smell as the heat from the engine will warm the tank forcing fumes out the vent. Natural occurrence. Stick around, there's lots to be learned from this group. Glad you stopped by.
This is normal and happens whenever a bike's heat soaked engine radiates that heat (hot air rises) onto the bike's gas tank directly above it. All motorcycle gas tanks have a vent hose that vents gas vapors out of the tank, otherwise it would pressurize the tank, not safe.
When the bike is parked outdoors, the fumes dissipate into the air and you don't notice the odor, but in an enclosed garage, you do. I suggest you leave your garage door open for a while after a long ride, so the fumes have time to dissipate.
Thanks, but no I'm not refilling the tank at the end of each ride, so that's not the issue.
So, quick update. I went on a ride today with my husband. 100 miles in about 3 1/2 hours. And when we got back the smell was still there but not as strong. He suggested wiping down my pipes really good before we headed out and he checked the engine thoroughly. He noted that the smell was not gasoline, but was exhaust. But again not nearly as bad after wiping down the pipes. So I wonder if something was just burning off that shouldn’t have been there. But I’ll still mention it when I take it for the 1000 mile service to Harley.
Okay, some do it, some don’t. Papa Zook blames engine heat. Could a tank lift be the determining factor? I have a tank lift and never had the odor.
That might help slightly Roy, but will not resolve the issue here. The primary issue is for sure parking it hot, in a small enclosed area where the gas fumes collect. The best cure I've seen for solving that are adding a set of Love Jugs fans. They are manually switchable on or off, so let them run for 5 or 10 minutes after parking it and the problem is solved, that or leave the garage door open.
Her mentioning that the trike is new and is just now hitting the 1000 mile mark, is an indicator that she could be smelling some "new bike burn off" smell from the engine and pipes as well.
Yes, the reason it's more pronounced is that below 1/4 tank, the volume of air/gas fumes is greater since there is more room to expand. If the space is filled with gas (a liquid) that resists expansion, then little to no fumes will be forced out the vent tube and into the garage.
So we were at Spring Bike Week a couple of months ago and we came to an area filled with vendor tents. I noticed that it smelled like strawberries and looked to find where it was coming from.
Well … it was a vendor selling “gas additive” that made the exhaust smell “Just Like Strawberries” No kidding … other smells were available but they had a show bike running outside their tent the whole time. “Strawberries”
This was a great option for you IMHO
Boatpaddle
