I do not like scraping idea's, but some times it is done because I looked into an idea that was bad.
IF the engine was able to be offset with in the frame work.
If the engine was mounted lower than it is now, than the chain line would run under the seat line more, and all may adjust and work out easier. I really like the idea of a chain guard style seat base, but that is me, as I always wonder what would happen if a through a chain while rideing. Just step back and look at solution's that can solve the issue, that is if you still want the seat level low, if you can be higher like that than all should work out, but you have to piece it all together in your mind and than to paper. Need to feel like I am helping some one.
