Rebel RT
You are at least getting things done with it. Looking good, and soon it will be all done. My wife is the opposite, seems she does all she can to keep me from getting things done with the trike, but I too hope to have it all done soon.
Welding
Tack welding batt box and rear floor board brackets, some of the wiring will be hid under the gas tank, Tack welding.JPG-Rear FloorBoards.jpg The gas tank tunnel is 3"+ wide, wow! Tomorrow will be to the welder for front floor board TIG welding brackets and machining...:wave4:
FloorBoards
Maybe overkill?FloorBoards.JPGAnd RebelRouser is tabled again, Tabled Trike.jpgOrdered the rear fender, takes 7 days to make it then ship. The fender is holding me back from making the fender (fiberglass) brace's and the lights. Need taller tires up front and shorter shock towers? EDIT: I just noticed the numbers in the date and time, crazy, :wave4:
Maybe overkill?View attachment 83568And RebelRouser is tabled again, View attachment 83569Ordered the rear fender, takes 7 days to make it then ship. The fender is holding me back from making the fender (fiberglass) brace's and the lights. Need taller tires up front and shorter shock towers? EDIT: I just noticed the numbers in the date and time, crazy, :wave4:
Don't ask me about overkill, lol, the footboard extensions look fine to me.
Looking good, should be a fun ride!
RebelRouser
FloorBoards in and mock up the shifter and foot brake,HPIM4173.jpg-HPIM4174.jpg Machinist is making the threaded M-14 2. square 1. x 1.25 bung for the shifter brace,:gah:
OMG! What about this winter weather across the States in Feb. Here it will be 77* today and tomorrow, :>(
Busy
Keeping busy between the shift linkage, foot brake, and now the rear axle spacer came in from the machinist, and still waiting for the rear fender and new tires up front.
Wife comes first
If wifey is not happy, NO ONE IS HAPPY!!! So it's back to her eScooter, drilled the new mounts and wire holes, setting up the box for rubber ligning and spacers for the taper in the sides of the batteries, two will be on their sides because of proper seat heigth which will be on the top of the box.eScooter.JPG-HPIM4182.JPG-1eScooter rear.jpg:gah:
eBay LOVE
Just to bring you up to date, Honda Rebel shocks.jpg-Fender time.JPGChanging the shocks for a stiffer ride, Shift linkage is figured out need spacer made, Moved brake pedal inward of upper frame rail, looks and should work better. And now it is fender time, wow lots of trimming and locating, I hope to follow the radius of the outer rim, BUTT!!! this rim and tire looks like "WHEEL PORN"...:D:clapping:
Rear Fender
Setting up the rear fender for marking and cutting, any ideas?, Fender time.JPGRim is 18" and tire is 24" tall. I hope to follow the arc of the rim...
Could you set the fender on your tire at the height you need and then use a home made compass to mark a line at the radius you want from the center of the axle?
You would have to center it front to back allowing for chain adjustment.
That is a good idea, kind da did that myself.I used 1/2" spacer blocks to keep the fender up off the tire, from there I was measuring for support arms that are supported by the axle.You can do the same thing, say you need a inch clearance, than make one inch blocks and tape down on inside of fender, set fender over the rear tire they way you want it, maybe tape to tire so it does not move, than tie a string on the axle, measure the distance you like, tie a marker or pencil to the string at that distance, mark away, should do it just fine. Keep everything the same and you should be able to do the other side just the same.The other way I seen was mount the fender to the tire and than they used a small hand tool and cut out the fender to the shape they wanted it, but these guys do fenders all day, LOL
The Trikester
HPIM1809.jpgI built the "Trikester" in 2014 for some local riding fun, The fiberglass fenders were a bitch, Then the eScooter-HPIM1831.jpgThe eScooter has a 16" high rounded wheel and the Trikester has 18"x8 wide wheels, swap meet fender blanks...EDIT: Can you see the little driving lights in the front lower frame rails?
Fender square
Where to start? Measure the tire height 24" plus 1" for fender clearance, so now I have a 26" tire and a 32" fender Diameter, This is the only fender I can find that is 11" wide, Then the overall width of the tire, also notice chain and brake clearance's. Square Fender.JPGBottom side up - square the length, then the width and do not forget the top of the tire (3 levels) Mark the tire top position plus 3/4- 1" Now measure that mark to the top of the wheel opening, mine was 6" on both sides (wow! lucky me) Transfer the mark to the outside and look for squared sides, mine was pulled in 1/8 on one side and 3/16" on the other, not to bad for a fiberglass molded part-Square sides.JPG Can you see the centering marks, and I must remember the chain adjusting and the fender will be attached to the swing arm NOT the axle, :gah: Now I am ready for rough cutting...
Rear Fender
The rear fender will not work according to my liking (fit), The 32" length is just to much arc, and I have tried everything, but for the sake of looks maybe I can use it with "Shenanigans"???:gah:
Coil overs
Coil over shocks and  brackets.jpgThis virus thing is really cramping my style, a little slow but still a go-go, need to change the front tires, some machine shop time, then I can set ride height again.
It is slow going these days, but at least we are still going and doing things, just at a slower pace.Style and looks is what caught me up in the new front end I am building. Machinist hit me up yesterday, guess some still work, going out today to see what is up and how much they got done for me. I just do not have all the tools needed, they do, and the guys are not charging me crazy prices for their time. Looking good, sure things slow up, but you keep going and eventually it does all get done, okay that is my outlook for now, LOL
Mock coil overs
Coil overs are in mock upCoil overs-shifter-floor boards.jpgSpacer for the shift linkage at machine shop and floor boards waiting final welding. I just might have met a new friend today while out bicycle riding met him on his Reverse Trike about 6 blocks away from my home, talked a little while both agreed this virus sucks...
Little Things
HPIM4228.JPGI want the upper shock brackets to be adjustable, so I picked up some 3/16 x 2" x 5ft flat bar and went to work on them, and started on the gussets needed to be made all over the frame, :clapping:
shock towers
New tires, DOT-New tires.jpgShock towers adjustable-New shock towers adjustable.jpgNow have 6" ride height, 7" sitting static, lowest point is front rim 4.5", Put a 1/8" steel plate under the brake and MC for better placement, gussets cut but not welded yet, need more clearance for the frame to exhaust bend, :gah:
DisAssemble
Looks like all the bike and car meet ups are being canceled,:mad: lock down is a bitch but I am so relieved to be retired with steady income and a big garage with a project getting closer to FINISH...Time for DisAssemble final TIG weld and paint... TrikeTalk will not let me post any photos? Or click on others "LIKE" So what's the use?:gah:
RebelRouser
Rear left side (2).jpgChains-Wires-BrakeLine.jpgWow! my thread is working again? Mock ups are pretty much over and everything is ready for finals, would you damn believe I take the 520 chain (Honda) to the bike shop for cutting to size and they loose the master link and then they say it was never there... more set backs, AND you know how much I love wiring, YES I would rather have a root canal:gah:
Yes, it has been a bit of a treat to watch this project form into completion. Wiring can be a pain in the butt, but it can be a bit relaxing, at least for me it was. Hope you the best with this final step, looks so nice, makes you want to ride it.:D
RebelRouser
1-Ride heigth adjust.jpgFinished is ride height, suspension, chains, shift linkage rod and exhaust do not want to play fair so I'll make some adjustments to the frame uprights, and be back on the rear fender/wiring and braces. About noon time It's 90 degrees in the man cave, NO wind, :Shrug:
Joe Henry
