Question re Installation of CB noise suppressors on 2003 Honda GL 1800
I have installed the Honda OEM CB unit. There are three noise suppressors that are required to be installed - 1) on left side behind driver, 2) on right side next to storage pocket and 3) on left side below storage pocket. I found 1 and 2, but I cannot locate No. 3. All are supposed to be white connectors as was 1and 2. I found a connector that is the same style plug-in, but it is grey.
Does anyone know where the No. 3 connector can be found or if the “grey” connector is the right one.
thanks for any input.
Ken
Ken
Sorry, the only connector that I find on left front is “black” but it does fit the noise suppressor connector.
Thanks for the response. I traced the No 2 suppressor to the right side fan. I traced that black connector to the left fan and so I installed the No 3 suppressor there. Will see how it works tomorrow.
Again, thanks for your thoughts.
Ken
Problem solved
I purchased and installed the Ground Loop Isolator and problem solved — no more high pitched whine through the auxiliary port. Nice to have a place to go to get the right answers. Thanks for the help.
Ken
CB installation
This shows the proper places to install the 3 filters:
http://goldwing.eurekaboy.com/cb.htm
Thanks for the information. My installation was the same as shown in the video with the left noise suppressor being connected through a “black” connector - - the instructions from Honda are incorrect as it labeled this connection as a “white” connector. That is what caused all of my confusion. Anyway, it has been correctly installed and works great.
Thanks again
Ken
Walter Bunce
