The parking brake light is staying on even tho the parking brake is completely up. What's going on with my 2017 freewheeler it only has 1300 miles??
First I would check for any codes. Next I would adjust the brake cable.Check the connector for damage or corrosion. Next I would adjust the sensor gap. Gap at end of sensor and magnet should be .177-.197.Disconnect sensor connector.Loosen jamnut. Turn sensor and adjust gap. If that dosnt do it I would replace the sensor and magnet.
Welcome to Trike Talk, Do you have any warranty left?
Pull up with your hand the pedal, does the light go out?
There is a switch on the pedal that turns the light out
All.of the above. But it most likely being the gap. I'd start there. If you had a CEL you know you had a code. No CEL. Not likely to see anything.
