Parking brake
First I would check for any codes. Next I would adjust the brake cable.Check the connector for damage or corrosion. Next I would adjust the sensor gap. Gap at end of sensor and magnet should be .177-.197.Disconnect sensor connector.Loosen jamnut. Turn sensor and adjust gap. If that dosnt do it I would replace the sensor and magnet.
All.of the above. But it most likely being the gap. I'd start there. If you had a CEL you know you had a code. No CEL. Not likely to see anything.
Bullet Proof
