New member with some questions
Oct 13, 2017
2
2
Boerne, Texas
Hi there, I’m Tim and am a new member to this forum. I’m rather intrigued with the Stallion trikes, but at 6’ 2” I wonder if I would even fit on one. I’m not even sure I’ve seen one in person much less sat on one. Also, was there only one or two engines put into these? Finally, does the a/c and heat really help much in hot/cold weather? I am in Central -South Texas, and it can get pretty warm down here!
Thanks for checking in. The ac helps in town when doing stop and go. It works better if side curtains are installed to hold it in, same with heat. The Stallion has only ever had one engine which is a 2.3 liter 4 cylinder 145 hp Ford Ranger. The pedals are electrically adjusted and you would probably be okay. It depends a lot on your leg length.
Enjoy and ride safe
Heck, I'm 6'6" and I do just fine!!
Gyl
