I've tried the link for the service manual several times and each time it fails.....any suggestions? Thanks![]()
Looks like Trike Talk's redirect program is not working. Try this link: http://www.junkmaster.com/kj5ix/MTServiceManual.pdf
Did you fix this problem??i have a 88 goldwing with a motortrike conversion . it does not have airbags on it, only air progressive shocks,i get a lot of movement from side to side.rocking or rolling motion, all joints are tight, has anybody welded brackets on their conversion, and installed air bags? if so what air bags did you use? i have even thought about using a sway bar ,like hannigan uses. thanks nobob.
It has been a long time in the making, and is now Finished.
It can be found here.
Motor Trike Gold Wing Trike Service Manual:
The link doesn’t workIt has been a long time in the making, and is now Finished.
That link doesn't work because it is 8 years old. Maybe someone can see if they still have the download and can send it to you. Good LuckThe link doesn’t work
Does anyone have this?
