Motor Trike Service Manual Finished
i have a 88 goldwing with a motortrike conversion . it does not have airbags on it, only air progressive shocks,i get a lot of movement from side to side.rocking or rolling motion, all joints are tight, has anybody welded brackets on their conversion, and installed air bags? if so what air bags did you use? i have even thought about using a sway bar ,like hannigan uses. thanks nobob.
Did you fix this problem??
At the end of the year mine developed the same problem....
It has been a long time in the making, and is now Finished.
It can be found here.:)
Motor Trike Gold Wing Trike Service Manual:
http://www.junkmaster.com/kj5ix/MTServiceManual.pdf
I have a ‘95 GL1500SE with a Motortrike Coupe SA kit installed early 2008. MotorTrike no longer has any documentation on this kit. I am hoping I can obtain a copy of the manual. Please do let me know if that’s possible because the link no longer works.
Thanks so much.
Anthony
Roger71!!
