Looking for information on building a mid engine vw trike.
If anyone has any drawings or pictures of frames and engine/trans supports. Thanks Jim
ThanksI posted a link on your New Member thread.
Is there any drawings on here on how to fab up mounts?The trans does not HAVE to be upside down.
The typical way to do it is remove the diff unit out of the side of gear box and walk around to the other side and stick it back in.
Of course there is things to take care about, the main one is setting the gear backlash. But if you are using the same parts that came out of it then at maximum you may re-arrange the shims that already exist.
I turned my trans upside down primarily to lower the height the engine is off the ground. It is very uncommon and is not an easy project. If you are familiar with rebuilding tranaxles and have the tools and a machine shop at your disposal.....then it is do-able.
take your time . Still in the gathering info stage. Hope you get well soon.Hey....it may take a bit.
I had a stroke the other day and am just now returning home.
I will get to the shop one day soon, will try to remember your info while there. Everything is on the server at work.
Yes the engine noise, heat, ECT is BAD ......almost as bad as riding a Harley.Not sure on a trike but I have built a couple of mid engine sand rails and did not care for the engine noise or heat and went back to rear engine design.
A trike woukd be hard to build unless it is 16-20 feet long.![]()
