Does anyone know what this little container in the right side of the lower faring is for?
it appears to be empty?
Its the overflow/return tank for the radiators , When you fill it make sure you use the right antifreeze, That bottle looks awful clean....Is it a new Trike...And if so bring it back to the dealer...
Yep it is your coolant reservoir. Should be full to the line on it. Might want to get it checked out - see your owners manual or service manual.
2016 tri is a 103 engine & water cooled. Nice to have a 117 but not sure if water cooled. Are you sure it is 117 ?
Thanks for your question , when I bought the bike I got paperwork showing the bike originally having the 103 engine with water cooled heads, the original owner had HD install
the Screaming Eagle stage 3 kit with the larger components to supposebly bring it to a
117 ci engine, what confuses me is there is a see-thru container mounted on the frame in front of the gas tank that I thought was the coolant reservoir ,
This is the other container
That container is for brake fluid.....
I just did a search.
Harley's new Screamin’ Eagle Stage III 103 Performance Upgrade Kit (P/N 92500028, $969.95) may give your bagger that extra grunt for smoother running uphill. This street-legal, Stage III kit gives 2014-later Harley-Davidson Touring models with an Original Equipment Twin Cam 103 engine a boost in everyday performance while maintaining the factory warranty. Designed for use with stock cylinder heads, this street-performance kit produces big torque gains at lower RPM, with the potential to produce 88 horsepower and 100 lb-ft of torque.
The Stage III kit includes high-compression 10.5:1 pistons, big torque SE-585 cams, Perfect Fit pushrods, a high-performance diaphragm clutch spring, high-lift valve springs and gaskets. It does not fit Trike or Twin-Cooled models, and installation requires the separate purchase of primary cover gasket. All EFI-equipped models require ECM calibration (priced separately). See an authorized Harley-Davidson dealer for details. Labor cost not included.
NOTICE IN THE info "It does not fit Trike or Twin-Cooled models"
I think you need to have a dealer tell you WHAT you have.
First, let me thank you for educating me about my bike, now, I went back to my paperwork
and I need to revise my previous info, it shows a part no 92500018 described as a stage 4
race kit for the 103 CI engine
I like the perfect fit pushrods :Shrug:
