Kuryakyn Fairing lower grills with LED LIGHTS
Apr 7, 2020
2
2
United States
Kuryakn LED tracer lights will only work on a trike if all your lights are LED’S. If you have non LED lights on your bike the BCM thinks there is too much of a current draw and possibly will shut down. The work around is to have all lights on your trike LED’S. I am installing mine on Thursday and I will let you know if the work around works.
I have no issue with them on my 2019, work just fine and I have a mixture of LED & Non-LED on my bike. Where did you get the information they will not work?
Oh a tip for you: The bottom 2 screws on the lower fairing mount have plastic locking stuff on them and when you try and take them off will sometimes just spin around in the fairing housing. Get a pencil type soldiering iron and apply heat to the back side where you see the captive nut flange, it will heat up the captive nut and screw so you can remove the screw and not spin the captive nut in the fairing. Be careful not to touch the fairing or get it too hot as it will melt fairing parts. I taped around the area to prevent damage.
FlintM
