It seems we have a recall regarding the secondary master cylinder on the front fork, my local honda dealer said it shouldn't affect a trike said he would be happy to check it out.:wave4:
Roadsmith was nice enough to respond to this issue as posted earlier here.
We have a Lehman Monarch II and after PM to the Lehman rep on this forum and a separate e-mail to Lehman through their website I have yet to hear from either. Oh well....
Paws,
I am home recovering from surgery over the holidays and I tried to send you a pdf on both the recall and any possible maintenance that you can perform to prevent this situation. If you can PM an email address I will send the pdf file I made for you.
As far as I can tell by the drawings, If the linked secondary master cylinder is still being utilized, it would be prone to this recall. Your Lehman has the linked system so it is suspect. There is an adjustment at the secondary master cylinder that I have found to be out of specs on 1 of 10 of the GL1800s I convert. This controls the application and release of the ADV and front caliper and is all tied to the rear caliper. When out of adjustment, the brakes will drag on release and I can see where they could remain partially engaged.
Jim
I will take mine in as soon as it warms up some, may have them flush the brake system and clutch while it's there.
