I have a 2022 tri-glide ultra and have trouble seeing the gauges at night. I was told that the lights can't be replaced with LED lights, but the entire gauges have to be replaced. Does anyone know if this is true?...Thanks
I had a 2011 and a 2017 now I have a 2019 Triglide..And all of them were more than adequate at night with gauge lights…Any chance the newer Triglides come with a dimmer switch???…Also I noticed that when I pull in my garage when it’s light out side and dark inside the garage the gauge lights come on…?..probably because it has a light sensor?..
Check out Dakota Digital. You will be amazed.
Do you have an owners manual. If so, check the section for lighting.
Yes I do, and I have checked. The only display that can be adjusted is the radio/gps display. Thanks..
