Harley gauges backlight
Oct 7, 2023
4
4
Medina
I have a 2022 tri-glide ultra and have trouble seeing the gauges at night. I was told that the lights can't be replaced with LED lights, but the entire gauges have to be replaced. Does anyone know if this is true?...Thanks
I had a 2011 and a 2017 now I have a 2019 Triglide..And all of them were more than adequate at night with gauge lights…Any chance the newer Triglides come with a dimmer switch???…Also I noticed that when I pull in my garage when it’s light out side and dark inside the garage the gauge lights come on…?..probably because it has a light sensor?..
Yes, there is a light sensor for the lights to come on, as far as I know there is not a way to adjust the gauge lighting, the infotainment screen I believe has an adjustment, check the owners manual
No gauge adjustments that I could find. I once thought my display was out (during the day).
At night, or when the sun goes down, they do have backlights.
Do you have an owners manual. If so, check the section for lighting.
There is no dimmer switch. The only display that can be adjusted is the radio/gps.
Yes I do, and I have checked. The only display that can be adjusted is the radio/gps display. Thanks..
Yep there isn’t any adjustments for back lighting.. outside of the light sensor that turns it on or off according to available light..
zigzag3227
