G'day all out there. I have a trike project that I started collecting parts for over the last 3 years. I will start at the frame I'm using a Yamaha 1000 frame this will be mounted directly to the motor with solid mountings. the motor is a 3.5 rover v8 running twin LPG carbies instead of the su's. the transmission is from an Alfa Romeo Alfetta it is a ZF3hp22 transaxle automatic with Di Dion rear suspension & inboard disc brakes .
the adapter you will see when I put up the pics is damn ugly but at $10.00 was cheap it came from a shut down analogue tv transmitter station. the Alfa has an unusual setup on the front of the trans it runs a tailshaft from the rear of the motor to the front of the gear box in the rear of the car. I have to get an adapter made to go between the rover flex plate & the Alfa torque convertor then I can bolt it all up to start sorting mounting the frame to the motor. ernie
![030_zpsdxehmxuu.jpg 030_zpsdxehmxuu.jpg](https://triketalk.com/data/attachments/11/11180-7dc7f644d85b52e86ce52180e96cc720.jpg)
this is the auto
![attachment_zpsq3brwfbe.jpg attachment_zpsq3brwfbe.jpg](https://triketalk.com/data/attachments/11/11171-a531c85f3c505c07ac8088f2ae59d6bf.jpg)
this is the manual gearbox
![IMG-20130116-00081_zps2pvvksap.jpg IMG-20130116-00081_zps2pvvksap.jpg](https://triketalk.com/data/attachments/11/11174-c6b58f1db43a9d144656a20669bcf779.jpg)
![029_zpsk0ngerpl.jpg 029_zpsk0ngerpl.jpg](https://triketalk.com/data/attachments/11/11167-81158ef2d6dd1fa9f1e0f9711c47db7c.jpg)
![027_zpsamvouzja.jpg 027_zpsamvouzja.jpg](https://triketalk.com/data/attachments/11/11178-10c7329e68820daf31ec4e76e3dd30d9.jpg)
this is the auto
