I purchased the above kit wanting to run one or two accessories from the fairing on my 2018 Tri Glide. This kit is for the right hand side dash panel [left side has Aux Lights and Fan and blank] where there are three blanks. The first step is to locate accessory connector 325B under the right cover and then add a fused harness to this connector. [ this provides power for the accessories]. The rest of the install is straight forward. The problem that I have is I had the HD Coolfan installed when I purchased the trike, and that is plugged into connector 325B, which defeats [I think] my Auxilirary Switch Kit. Also looking at the wiring diagram the Accessory Connector 4A under the left side cover does not have power to it - so I assume plugging an accessory into this switched connector will need a power source??
Thanks for any ideas/advice.
