Engine Oil warm Enough
Apr 19, 2015
885
347
Clarksville, TN
JC
Sitting last night complaining about a three hole fluid change I'm about to do....I said I let the bike idle for about 4-5 minutes and start the process. The Two guys I'm drinking with are telling me I can't do that....Gotta get it out for more time....really get it hot and shook up. I said the Oil doesn't know I didn't take it for it's last ride! They didn't think that was funny.....Anybody take the bike out for a ride before an oil change?
Yes and no
AS long as BOTH rocker boxes are warm and I mean warm to the touch you should be warm enough
Riding it if an option would be better Forcing air thru the engine would give it a bit more time to warm up to operating temps
I have done it both ways, they both will work fine
If you get nervous about idling your bike you can use as small box fan blowing whilst you have a smoke or a cup of java
engine oil warm enough
hi, this is my thoughts on the subject. Motorcycle, car, lawn mower any engine. I let it run, or Idle until the temp. gage get to normal temp or close to it. cut it off and drain oil. you can ride it for a few mins. or let it Idle. the oil will be hot and will have circulated sufficiently
This was confirmed to me several years ago my the then service manager at my local dealership. When you drop off your bike for service unless you are fortunate enough to have a 'wait for it' appointment the bike's going to sit - probably for several hours if not overnight. And the techs don't get paid to ride your bike to warm up the fluids. They just ride it onto the rack and let it drain . . . in most cases it will be at room temperature.
I too used to ride the bike to get everything up to normal operating temp before draining fluids. But then you gotta wait for things like the derby cover and the oil filter to cool enough to remove. Lately I just let it drain until it stops dripping. Heck you aren't going to get every last drop out anyway. Honestly I simply do not think it makes any difference. Just my opinion. Others may (and most likely will) disagree.
The little bit of difference in the amount of oil you get out is very small. Warming it up a little just lets it flow out slightly quicker.
With the multi grade(s) oil out today ("think about now") the hotter the oil gets, the actual *thicker* it gets, so by letting it warm up, aren't we really making the oil thicker, instead of thinner??
Flame suit on now (but *think* about it before you scream at me...lol
Right: Say you have 10-40 wt. oil in bike/car, when it's cold before starting, it's thin, but as it gets warmer doesn't it thicken up?? ;);)
Bet you never thought about it, "that way" did you??
My understanding is no
Multi Weight oil can lubricate @ the high end when hot
Say the 20-50
When hot the oil has the lube properties of a 50 weight but it really is not a true 50 @ that time
That said, I am old fashioned
I was that when the oil was warmed up to operating temperature more of the sludge and dirt had been suspended in the oil
That way it is NOT laying in oil galleries or the bottom of the crank case JMO
I guess if we ALL were a bit smarter we would use this
https://roguechopper.com/
Sure hope this does not get ugly like oil threads tend to
I use that Scavenger when changing oil. They say that if you just drain the pan, you don't get all the dirty oil out of it. Some is still in the crankcase.
Since the OE oil filter is on the front of motor, you make the mess twice because you take off the filter, then do it again when removing the scavenger puck. I've never had much luck with those special funnels.
Good reason to get the remote oil filter mount from Kevin at DK. No more mess. You screw the puck onto the remote filter base.
Yes it takes a little longer to do your oil change using the Scavenger, but that's just more quality time wrenching on your toy, and not doing honeydo chores...
Wow......So.....Taking the Oil for a ride isn't necessary as long as you've been good to it and said your goodbye in a sincere way.....Got it. I did it like I always have. Five minute idle ~ all three in under an hour. But I am now a bit more confused! lol
Marks2024
