Chasing a fender vibration problem on my InstaTrike
Been a while since I have visited here but I'll update everyone on my progress... For the most part, my vibration is gone... I can ride at 70-75 and all is pretty smooth... I believe that tire alignment is paramount to keeping vibration low...
If the cart tires are not nearly in perfect alignment with the rear tire, they are being "scrubbed" across the pavement and as a result, vibration occurs... I take great pains in getting my tire alignment to 1/16" or less, and the closer to perfect results in less vibration...
We must remember that these outriggers are a work around to a full trike kit, and as such, there will be issues that must be addressed unlike a regular trike conversion...
I have tinkered with my Tow Pac kit for nearly 6 years now and as a result, know the adjustments and performance envelope of my kit pretty well...
Each installation on a different motorcycle will offer slightly different challenges and may require different adjustments than I use but again, I have been quite satisfied with mine after tuning, adjusting, and tuning some more... It takes time to get it adjusted to your riding style and weight...
Too much down force and/or too much tire pressure will yield quite a harsh ride... I run 32 PSI in my tires and this proves satisfactory for me... My down force is adjusted so that it takes a good firm 2 handed tug on the cart rim to move the tire on smooth concrete... I also have mine adjusted to compensate for road crown in the right hand lane, which is where I spend most of my time driving...
I also have a 4 degree Traxxion rake kit installed which makes mine handle a bit differently than one without a rake kit... I also run a car tire on the rear and a BT-45 on the front (double dark side for those familiar with that term)...
Don't give up on the kit - it takes some time and effort to get it right, but also realize that this is NOT a $15-20K conversion, so keep your expectations in line with the dollars expended...
Les
Gyl
