Has anyone here ever used the Bullet Brake on their GL1800?
Also interested. Curious if there are any ill effects with keeping pressure on the brake system for extended periods.....?
I don't park on steep grades often but when I do I use this:
https://www.acebikes.com/products/motorcycle-accessories/brakefix/
No loss of fluid of course and installs in 5 seconds
Ordered a Bullet Brake this evening. Thanks all for the information and a special thanks to the OP for bringing this up and helping me spend some money. :clapping:
I have one on my 2021 DCT. I love it. I think Honda should put this on all DCT’s.
which model for your GW? I have the same and want to order
BB-05 is for Honda Goldwing...
I lost a few drops of fluid when installing. No biggie. Hardest part of installation was my banjo bolt was tightened by a body builder! To loosen it I used a 12mm box end and tapped it several times with my persuader (hammer). It then came loose relatively easily. I kept my old banjo bolt and washers. If I ever get another Goldwing, I will transfer the BB to that bike. I LOVE IT!!!!! One of the benefits is that I can now park the bike on a hill, set the BB, then put the bike in gear as an additional precaution without creating a bind-up condition on the trans. :clapping:
Under most circumstances, I simply leave my bike in first - and all is well. For the Wing Riders (DCT), I know why you need it.
This might be good for me in the one of two times I need it. Tried to get one - but had difficulty. maybe I will just carry a band to put on my brake.
Donald, get some of this from Harbor Freight, I used this to secure my pack on my StreetBob on a trip from Florida to Sturgis and back. It worked IMO better than bungee tie downs. I carry a roll in my trunk now wherever I go. Easy to use, just cut what you need
https://www.harborfreight.com/34-in-x-35-ft-black-hook-and-loop-cable-strap-57372.html
Just Ordered one $21.45 with shipping GOOD DEAL
I ordered the Bullet Brake weeks ago back in early June and since then it has wondered around California, Oakland and LA, then Bell Gardens, then they sent it to Frankfurt Germany, who sent it back to Buford GA, then to Atlanta, then to NJ and then on to Jamaica NY. So here it is July and it will be November by the time I actually get it. It’s a good thing I have a good sense of humour. But really, how stupid?![]()
The USPS must have taken a peek at your location and acted accordingly. But hey, your BB will probably be the most traveled one in existence. A treasure to pass down to your kids!(I got mine 6 days after ordering it.)
You'll really like it.....works as advertised and easy to install.
Just pump and fully release the brake lever about 15-20 times after install to allow any bubbles to float back into the master cylinder.
Brethren,
Just FYI,I Had to Bleed The Front Brakes On My '90 GW After Installation,
Ayatollah
