Bullet Brake Parking Brake on DCT Good or No?
Bullet Parking Brake
You can't go wrong with the Bullet Parking Brake.
It is well made and very easy to install.
Just make sure to put some rags under it when you take the brake line loose, just in case you drip some brake fluid, as you don't want brake fluid on paint!
I don't think it took 5 minutes or so, to install ours. Took longer to find the correct size wrench.
Ours is an 18 Goldwing DCT CSC Encore Trike kit.
It works slick and you won't move the bike once it is applied.
Simple design, that actually works.
Order it, we have had ours for about 1 year and no problems at all.
Good luck!
I have it on my '21 Tour, and I love it ,,,,,,,,BUT I have been fighting since day one with the pressure bleeding off the brake, occasionally. I always have a firm lever but sometimes, usually after riding, I will set the brake and when I come back the pin is still in but no pressure.
I was washing on the driveway recently and while I was hosing off the soap it just started rolling, slowly, but enough that it was going to get away. Last october in Gatlinburg in a parking lot it let loose after 3 hours and rolled across the drive into a pick up truck, ruining a perfectly good rear door on my Roadsmith.
And yes, it has been bled over and over. I just returned from a trip to KD Cycle for a new door and help on this and we are down to maybe the ABS bleeding off sometimes??? no one has given me a plausible fix on this. I can park in the garage and stay fully locked down for several days, the ride it and it lets go.
I now carry a wood block, I hate it but not as much as I did the factory brake. After two warped rotors on the right rear I took the park brake caliper off. If anyone has an insight I would love to hear it. Last thought, Bullet Brake has been great, even sent me a new one to verify that its not the BB itself.
nmbr1soonerfan
