2010 Stallion Repairs
Aug 13, 2010
142
3
Milton, Fl, USA
I have posted these issues before and finally was able to get them fixed. First thing if you ever need your Stallion worked on and for warranty work and in the Penscola Fl. area, I recommend WORLD Ford of Pensacola. Next issue, Thoroughbred Motorsports stood behind their warranty 100%. The dealer made a phone call to them and it was taken care of. One day in and next day out, great work.
Issues:
Steering wheel was catching and very sloppy. They found the steering wheel bearings to be lose and not seated and the bracket to be loose. It was also recommended that I leave the tilt wheel in a neutral position because of the tightness with all of the cables.
I had clicking noise when applying the brakes in the front. Issue was that the front end was not tighten . The brakes and suspension was loose.
Cruise control was out and not working. Issue was that there is a plate that was bent from hitting something underneath and it was not making contact with the switch.
My breaks would squeak when backing up with the first applications. This is due to surface rust that happen this area due to humid conditions in this area "normal".
I enjoy my Stallion and would not trade it in. Happy riding to you all and hope this helps.
Dean
Flyboy7312
