Has anyone had a problem with opening hood, to find out that the light assy. Is resting on the front tire?
my hood never had this problem before....
I had that issue once and got some "Felt Pads", that are used under table/chair legs etc. Stick 2-3 together and then stick them on the metal piece where the hood latch meets, when the hood is being raised.Has anyone had a problem with opening hood, to find out that the light assy. Is resting on the front tire? my hood never had this problem before....
Thanks with that idea.....I was thinking of putting a stop on that spot myself.....I was wondering if the shocks are worn out.....scratching their heads at Thoughbred...I had that issue once and got some "Felt Pads", that are used under table/chair legs etc. Stick 2-3 together and then stick them on the metal piece where the hood latch meets, when the hood is being raised.
Add photos for your fix. It may help others.
Thanks!
