I have a 03 Goldwing with Champion trike and straight axle. Going to put new tires on it. It has 205/70R15. Could I use a 215/70R15. It give me a little more side wall and about 1/2 inch wider.
On 1800 goldwing where is speedometer? On 1500 it’s on the front wheel so rear tire size doesn’t effect speedometer. Only effects rpm to speedometer ratio.
Electronic output from tranny. :xszpv: :xszpv:
I had an o8 with a champion kit and there wasn't much extra room under the fenders and it was really tight getting the wheels on and off. Not sure slightly taller and slightly wider would fit, would be tight.
