2003 Goldwing Champion
Apr 21, 2016
25
8
Bartlesville, OK
Joe
I was wondering if anyone knows if part of the lights (no headlights) can be wired so that they would come on with the key in the accessory position. Or would it be best to add more lights?:xzqxz:
Not knowing the purpose of the light, I was wondering if you turned on your flashers to give you temporary light. Just a guess.?
You probably could get the tail lights and brake lights to come on with the aid of a relay controlled by the accessory fuse panel terminal but you would have to be able (and remember) to shut it off before going into run mode. The turn signal circuit is a bucket of worms and you might do damage. I can send you the wire diagram for the tail/brake lights if you don't already have them... :xszpv: :xszpv:
Short of that adding lights controlled by the accessory power terminal is always a good option. ThumbUp :D
Marks2024
