TriGlide Rear Brake Upgrade '09-13 Models
Longbeard71
100+ Posts
Nov 3, 2018
150
111
Talbott, TN
Clay
There was some old post on this but I wanted to see if anyone came up with an upgrade on 09 to 13 models. Did anyone ever try the 14 model rotor and caliper on one?
👍 Deglaze the rotors, do the break in procedure to bed the EBC Double H’s, flush the brake fluid and you’ll think you’ve installed an expensive upgraded brake kit.
I've heard EBC before. Can't seem to find a source of supply. Last I looked EBC didn't list for TriGlide.
Regarding brake rotors, if you go back on the Triglide thread to an entry dated April 3, 2014 and follow it out to line item 109 dated Nov 12, 2015 you will find that a 2002 Ford Focus front brake rotors is compatible with the Harley Rotors with some machining required. Line item 109 has some drawings/pictures that show what machine work needs to be done.
I think this is a link to the post you mentioned. It is a long thread. This link should go right to post #109.
Dieseluladstron
