Yes. Still use the stock spacers unless replacements come with the new springs. Or the directions call for cutting the stock ones down. The extended caps just sit on the top of the forks and are solid. They have nothing to do with the internal parts.
Finally got it! Used heat, drilled hole into bolt, drove bolt extractor into it then clamped on with vise grip, standing on stool to get above it good & pulled upwards while turning.Thought of that too. I can hold rod still by hand and turn bottom drain bolt as well. Got to quit for today on it. Thanks for help. Appreciate it
Finally got it! Used heat, drilled hole into bolt, drove bolt extractor into it then clamped on with vise grip, standing on stool to get above it good & pulled upwards while turning.View attachment 131008
