Jd1a
90+ Posts
212 mile lunch run to Bagdad, AZ. Copper County Bar & Grill, good food.
Pretty good for an online order, hope it works good for you
Yesterday I completed my first “Iron Butt”… Me and a buddy booked 1032 miles riding round trip from Lisle Illinois to Turrell Arkansas and back.
19 hours and 25 minutes. Left at 3am and FROZE (for June at least… had to crank up the grips to 11!). Glad I had my heated jacket liner… 45 degrees in June! WT?
Reached 94 degrees in Arkansas, quite the swing!
Waited out an intense “20% chance of rain” gully washer in Turrell.
Only soreness I’ve had today is in my right elbow. Thanks to my Butt Buffer sheepskin seat cover, all good on my bottom end…LOL!
Already planning next years run!
I must be getting close to having ridden 200k miles on Tri Glides.
Up until yesterday I had had only one time that I plugged a rear tire with a slow leak. It was back around 2015, on a road trip a few States over, and there was a wood screw imbedded in the tread of the right rear tire.
Yesterday (should have take some pics) when checking tire pressures, the right rear was low on the 2019 Tri Glide. Got some soapy water and found two pinhole leaks.
One was just a small hole, the other had a very small finishing nail in it, not much bigger in diameter than a staple.
Pulled it out and then plugged both holes.
Gotta get some more plugs to keep in my tool kit, those were my last two.
I carry a plug kit and a little compressor always.
The last time I had to plug a tire on a motorcycle was more than 20?years ago on the rear of my New VTX 1800 With only 6 hundred miles on it…I plugged it and then used sealer in it Rode it like that out without it losing any air till the tire itself wore out … Driving into Manhattan every day with my vehicles. I was an expert at plugging car tires on the road. Seemed like once a month I’ll get a flat ‘Plug and seal i never trust a plug alone..With my ATC’s I had to buy plugs by the dozen...
And one time I had a pice of shale punch a hole in the side wall of my Big Red’s rear tire…
Being I only rode it off road … caveman style I took the tire off the rim got a big bolt put a piece of rubber on both sides of the side walls and with large flat washers tightened it up and rode it for years like that……
:laugh::laugh::laugh:
Made me smile!
