Lehman Trike Trunk Lock
Jan 9, 2023
1
2
Lincoln, ND USA
Mark
Hello,
I purchased my late father in laws 08 HD Ultra Classic with a Lehman Renegade trike conversion. I'm having issues with the trunk door opening up when I ride. Is there a lock or latch kit that I can install on the door? I've tried adjusting the door but it still wants to open up.
Hello,
Mark.. Welcome to Trike Talk..👍👍
Hello,
Welcome Sir. There have been several posts on this site about the same thing. You can also search Harley Trike Trunk for more.
Hope this helps.
Up date: I have got this lock replacement worked out but it will only work on the Lehman built bodies. There is a web site called truckcaportopperreplacementparts and they have more stuff than I ever dreamed was even made.
The lock system on the Lehman bodies is turned by a 1/4 inch square shaft operating the cable releases. Next time you have one break order a lockable "t" handle long shaft unir from these folks and throw away the OEM lock then drill two holds using the "t" handle rear flange as a template, guide the long square shaft through the square hole bolt it to the trike body using lock nuts, problem solved.
Cost, about $30.00
T handle conversion
Hope this helps.
Up date: I have got this lock replacement worked out but it will only work on the Lehman built bodies. There is a web site called truckcaportopperreplacementparts and they have more stuff than I ever dreamed was even made. The lock system on the Lehman bodies is turned by a 1/4 inch square shaft operating the cable releases. Next time you have one break order a lockable "t" handle long shaft unir from these folks and throw away the OEM lock then drill two holds using the "t" handle rear flange as a template, guide the long squrae shaft through the square hole bolt it to the trike boody using lock nuts, problem solved. Cost, about $30.00
Could you go into a little more detail on how to do this, thxs
Hope this helps.
Newbie here. Picking up my 03 Road Glide, Lehman trike this Friday. 🎉🎉🎉. My latch is Broke and currently rigged with a pull cable. Any Pics of the repair you mention above?
Thanks Much,
Bobby
God Bless!
Hi all, newbie here to trike talk as I just got a 2008 Goldwing Trike (Lehman). The big trunk will not open. I found the release cable in the small trunk and used pliars to pull it with no luck. I lifted the seat and found the emergency release cable and when I pulled on it, it broke completely. Does anyone have any tricks on how to get this darn thing open. I don't want to pry it off or break it as there is a mural painted on the trunk. Any help is appreciated. The original owner said it just has the one latch right in the middle but with the one cable not pulling and the other one broke I am stuck. thank-you!
When pulling up on the release cable in the small trunk, push in at the same time the top on the big trunk lid to take pressure off the latch. I've found this works with releasing the latch with very little effort on pulling the release cable in the small trunk on mine.
Bullet Proof
