Custom Dynamics delivers
New Orleans Kevin
200+ Posts
May 4, 2021
434
394
Arabi, LA
I’ve got an array of Custom Dynamics lighting on my 21 TriGlide and 17 FlHXS. Recently the Trike threw some codes and shut down all lights except headlight and brake lights. Diag revealed Bcm was shutting down as something was overloading . It turned out it was the pass through harness for my vent light ( with the module built in) on one side . One call to Custom Dynamics with an explanation of issue and one call to get process and get part shipped and then a few minutes to plug a new one in once it was delivered , free of charge, and all lights are up and running again. Kudos to Custom Dynamics for lifetime warranty and actually living up to their promise!
+++On CD. And thats the wonder of the BCM...allows the use of micro switches, eliminates a big honking fuse panel- with two miles of wiring could you imagine circuit protection for all that? If anyone has added passing aka auxiliary lamps all you need are the lamps/ buckets, a bit of wire, a on/ off switch and your in business (connector 109A). The BCM takes care of circuit protection and will turn off the aux lamps when you hit the high beams then back on again when high beams are off. And thats only one circuit!
With all of my Triglides my dealer just flashed the BMC/EMC ? No charge so the spotlights will stay on with the high beams…👍
Same here . . . and I run with high beam and running lights both on during the day. It is amazing how much better one's visibility is with high beam on even if running lights are off.
I've had a totally different experience with Custom Dynamics. I will never buy another product from them.
Please share the experience as Custom Dynamics service and products have always been great and reliable…..
Custon Dynamics return policy.
This item is defective and will not fit as described in the installation instructions, why am required to pay the return shipping on this defective item...?
Here's my return policy.
I will pay the return shipping. Then I'm going to express my dissatisfaction with "Custom Dynamics" in our HOG newsletter and on social media including the Tri Glide websites.
As you are entitled to do. I looked up the batwing led light kit for vent and it says it fits on their site. I have it on my 2021 and it fit perfect . I don’t understand why it’s not fitting on yours . But maybe once they get it back they will be able to explain why it’s not fitting. Good luck!
Perhaps you didn't read all of my original post, so I'll repeat again just for you. "The vent trim retaining tabs do not line-up with the fairing and will not allow the vent trim to "snap" into place"
Custom Dynamics has warrantied a couple lights for me one of which was an 800 dollar headlight. I wouldn't buy anything else, good folks!!!
Yes I understood completely your issue and have installed a couple of those myself and never had an issue . Everyone I’ve installed had double sided tape and snapped into place with no problem.
jhlesher
