Custom Dynamics delivers
New Orleans Kevin
200+ Posts
May 4, 2021
336
258
Arabi, LA USA
I’ve got an array of Custom Dynamics lighting on my 21 TriGlide and 17 FlHXS. Recently the Trike threw some codes and shut down all lights except headlight and brake lights. Diag revealed Bcm was shutting down as something was overloading . It turned out it was the pass through harness for my vent light ( with the module built in) on one side . One call to Custom Dynamics with an explanation of issue and one call to get process and get part shipped and then a few minutes to plug a new one in once it was delivered , free of charge, and all lights are up and running again. Kudos to Custom Dynamics for lifetime warranty and actually living up to their promise!
+++On CD. And thats the wonder of the BCM...allows the use of micro switches, eliminates a big honking fuse panel- with two miles of wiring could you imagine circuit protection for all that? If anyone has added passing aka auxiliary lamps all you need are the lamps/ buckets, a bit of wire, a on/ off switch and your in business (connector 109A). The BCM takes care of circuit protection and will turn off the aux lamps when you hit the high beams then back on again when high beams are off. And thats only one circuit!
With all of my Triglides my dealer just flashed the BMC/EMC ? No charge so the spotlights will stay on with the high beams…👍
Same here . . . and I run with high beam and running lights both on during the day. It is amazing how much better one's visibility is with high beam on even if running lights are off.
Mr Tool
