2012 Goldwing Motortrike problem
Sep 24, 2020
2
2
Diana, TX
Barry
My riding buddy has a 2012 Wing M/T conversion.
The right side of the trike leans to the outside when his wife rides with him. Adding air to the suspension does not cure the lean.
The trike also has a wiggle at about 60-65.
Any help or suggestions will be appreciated.
Barry i can't help with your buddy's problem 'But i'm sure someone will chime in as the day wears on with some suggestions...
But I Can Welcome You To Trike-Talk...:wave4:....:clapping:....
I have a '12 with M/T Razor.
First thing I would do is measure from the ground to the body fender height directly above both rear tires. (on level ground or driveway etc.) Should be very close to one another.
Also, raise rear end and check springs/airbags
Let's go from there.
ps. mine gets a butt wiggle sometimes when going over a uneven spot on the highway.. lasts less than 2 seconds
if you want answers call me. 717-414-6142. i can walk you threw the whole set up on that trike. if i'm out riding and i don't answer. leave a name and number and tell me that its about a motortrike and i will call you back as soon as i can.
