Dead Wards Fan need recommendation
Sep 24, 2010
885
193
Shawnee, KS
Scott
Title says it all. 2010 Triglide. I have the Lehman running boards. I need a new fan as the Wards fan, after 7 years has died. Give me a BEST fan recommendation! KC summers are brutal.
Love Jugs, Mighty Mites are just like the Wards Fan. Look the same.....
Mighty Mites is the way to go! If a fan goes bad, less than 5 minutes to change out! Plus, they absolutely back their product!!
Yep, the Love Jugs Mighty Mites are very much like the Wards fans but better because they are serviceable. The fans and switches can be changed where the Wards cannot. Jason sealed the switch assembly and the fans he used are computer fans with the 4 corners lopped off to fit his housings.
The Mighty Mites have been on national back order but should be back in stock today or Monday is what Dave, the owner of Love Jugs told me earlier this week. Any TT member or visitor that orders any LJ products or fans from me at www.buylovejugs.com, I will make sure you get taken care of should they ever fail and totally appreciate you supporting this forum.
Ask nucseal...
The Mighty Mites have been on national back order but should be back in stock today or Monday is what Dave owner of Love Jugs told me earlier this week. Any TT member that orders them from me, I will make sure you get taken care of should they ever fail.
Ask nucseal...
Yes indeed;) Easy to replace parts. I had 1 fan go bad, Pappa Zook took care of that. What else needs to be said . BUY THEM
I am definitely one of the many happy campers taken care by Papa Zook and the owner of Love Jugs. Like I said before everyone stands behind this product.
Ask nucseal...
I am also one of the very satisfied owners of LJ Mighty Mites. I had Wards fans on my '14 TG years ago, and when I traded in for my '17, wanted to replace them. Went with MMs from Papa Zook and very satisfied. One of the fans died a year or so down the road, and Zook contacted Dave the owner of Love Jugs, who then contacted me directly. 72 hours after I emailed Zook, I had a new fan from Dave in my hands. Can't beat that for customer service all around!
Well that’s interesting as I just had my wards fans quit on my recent trip. Mine however is the temperature sensor fans still work when ran directly only using toggle to control on and off. Haven’t verified switch truly bad as one connection looked a little grungy. After a some contact cleaner I might get lucky. I was about to post this and image my surprise a similar post already made. Did intend to ask contact info to source a love jugs temp switch, sure there’s no reason it won’t control my wards even if slight wiring connector change needed
Well, silly me. I just read love jugs installation instructions and no mention of a temperature switch. Back to the drawing board. Busy today and still haven’t tried cleaning the one connection coming from the switch.
you can work the temp switch from the wards into the wiring for the love jugs. i did and it works
I believe but have yet to verify but my temp switch has failed. Switch isolated from circuit wired direct fans run so don’t need replacement fans yet.
jhlesher
