Changing handlebars
Aug 9, 2019
44
39
Ocala, FL
Charles
When changing handlebars to 2+2 wide sweeper I assume that you have to also put new grips on. What grips have you used and why do you like or not like them? Thanks in advance.
Ride often, ride long, ride safe!
Drag Specialties, I like the nostalgic look and feel. Looks the same as HD but cheaper;) The TBW grip you have will slide off so it could be re used. If you work at the LS grip spraying inside with some WD 40, twisting the grip and shoving a pick tool down the inside you can sometimes get that grip off with NO damage
  • Like
Reactions: MDO
Avon Grips Chrome Air Cushion Grips with Throttle Assist. I like these because they are not too fat and the throttle assist is really handy in stop and go traffic.
+1! I went with the same Avon grips, but I chose the black ones.
I had used Kuryakin grips for years, but I like Avon better and they are less expensive.
Here is a link to the thread I started when I installed them, with pictures.
https://www.triketalk.com/forum/threads/46641-Avon-Velvet-Air-cushion-grips-for-Harleys
