Putting trike in neutral
Feb 17, 2020
43
23
Yantis, TX
Mark
Does anyone else find it difficult to get your Trike into neutral? My 2009 Ultra Classic was the same way. When trying to put into neutral I go up/down, up/down, on and on until I finally find the sweet spot for neutral. Seems that Harleys are just frustrating for this function. If everyone else finds it easy what are you tricks? I am not a novice rider but this neutral shift thing is very frustrating. Thanks
Too much lubricant in the primary. Should only cover the bottom of the clutch pack. See the service manual for line of where the lube should be.
Many times folks put too much in and it causes issues with finding neutral. I put about 28 oz in my 2019 when I change it. Depending on the model year and type primary cover it can be a little more or less.
If you have a heel shifter......When at a stop in first Clutch in ...Very gently tap it with your heel...
But technically Harleys 'DON'T' have a neutral, There is just a very small air space where neutral is hiding....:laugh:...
Oil,Adjustments does help finding neutral much easier. Also the RPM's,and Chain tension will help too. :D
Easy is another one of those relative terms UJM bikes don’t need any magical fluids or adjustments to find neutral every time it’s just a Harley Davison idiosyncrasy 😄 I had five new ones over the years and they all have their quirks as far as how to find neutral😁 Henry Ford was quoted as saying any color as long as it’s black Harley Davison is any transmission as long as you can’t find neutral
Easy is another one of those relative terms UJM bikes don’t need any magical fluids or adjustments to find neutral every time it’s just a Harley Davison idiosyncrasy 😄 I had five new ones over the years and they all have their quirks as far as how to find neutral😁 Henry Ford was quoted as saying any color as long as it’s black Harley Davison is any transmission as long as you can’t find neutral......😄..
Clutch adjustment And tranny oil
I 'm by no means a certified Harley Tech. From my experience a professionally adjusted clutch and top rated tranny oils are an absolute necessity. Two years ago is the last time I had it adjusted. Still working great :good: good luck Fred
Well I bought it with 6800 miles on it and have not adjusted anything. I would think that the Harley dealership would have done the correct adjustments when they inspected the bike prior to selling it. Oops, I forgot, most dealerships probably don't check their resale bikes. HeHe This bike so far has not had the oil migration issue. My next service is at 10,000 miles so maybe they can check all of these adjustments then. Thanks to all of you for your input. Nice to know that it is not my inadequacies keeping me from getting into neutral easily.
All good info here. As far as what year you got not real sure. But since it's 6800 miles I assume its the new motor (M8). Not sure to much on the hydraulic clutch adjustment, I don't have a manual for mine yet. Not 100% but I think my 2018 Street Glide was 28 ounces in the primary. I did one change at 1000 miles on it and traded it at 5000 for the 2019 Tri-Glide. Never really had no issue with it getting into neutral.
Also with out posting the long post I was going to, I'd check the primary fluid level or drain it and add what the book says. Had issues with this in the past with older bikes. In one such case putting the correct amount of oil in the primary cured my wifes problem with finding neutral.
Guys I'm telling you the secret is to use the heel shifter. I know, I know some folks don't like it but I gotta say I can't ride without my heel shifter . . . and I use an extended lever to give me more space on my footboard. I've had 9 different Harley touring models all with heel shifter and have never ever had any problem finding neutral on any of them. Now trying with the toe shift lever is a totally different experience . . . and not a good one.
Once I changed the tranny oil to Red Line with shockproof at the 1,000 mile mark, I have had no trouble finding N. In first, just a light heel tap will get it, and I can even hit N from second gear with a really light toe tap.
I use heel shift 95% of the time on my bikes. My toe shift is set to the point you can't get your toe under it. Toe down heel up. All of
my bikes, trike. 6 currently owned, 3 have them 3 do not. I won't count my wifes Tri-Glide, she's a different creature. Only reason the other 3 don't have heel shifters are one's a Sportster (1983 XLX) and the other two are PanHeads (1950, 1960). My '71 Shovel has a heel toe shift, but it's a solid bar, so you can't really off set it like the others. My '95 Evo was the first I could adjust heel and toe shifters. And it made a difference as far as "jamming" into gear but good quality oil in the tranny and primary seemed to help as much as anything.
I agree I like my heel shifter. I'd be looking to add one if I didn't have one.
Sorry, I forgot to mention the year. It is a 2019 and warranty ends in Feb 2021.
I have a 19 also.......Like i said before ....Very lightly tap the heal shifter cluch pulled in and in first gear....Very lightly almost no audible sound when the neutral light comes on..
I only have about 3 hundred miles on it...But this isn't my first rodeo with Tri-Glides.This is my third one....
I must have missed something Bob did you swap out the slingshot? for a Tri... Fred
Yea, A little while ago' Wife wanted it out of the garage it took up too much room, And my Sons won't drive it...And then there wasn't any traction in the rain. I had it for two years and only put on 12 thousand miles what with all the rain in the last two years...Also i missed the Motorcycle feel...I would look for more excuses but at the moment i can't think of any.....:)...
Congratulations I knew you really have a bar and shield .... heart. Fred
Congratulations Bob! ... The Slingshot curse has been broken :Joker3:
Not to hijack the thread, you'll have to tell us about it on the late night....
I haven't been on my Trike since last October when I put it in hibernation before heading to Florida. But we're leaving Florida this weekend and looking forward to getting back on the Trike in Wisconsin. Our Florida riding has been on the Sportster which is fun but isn't the comfortable Trike ride. I always found the Trike was easier to get into neutral if I did it just before coming to a complete stop.
This also works every time for me.
I have found this to be generally true on my 16 and now my 19 Trike. It is the same as I did when on 2 wheels.
Thanks guys for this tip. I will definitely try it next time out. BTW, I do not have a heel shifter. I do not like them and had it taken off before I picked up the bike. I know many like the heel shifter but it is just not for me.
I use to shift into neutral when coming to a traffic stop. But, during the Three Wheeled Riders Course the instructor strongly advised against this in case an urgent takeoff was needed. I countered that it just takes a quick clutch grab and toe down to get underway. He then said, well visualize an 18 wheeler barreling down on you...would you prefer to just release the clutch and throttle quickly out of harms way or take those extra steps you just described....Seconds Count!! I changed that practice....realize everyone's mileage may vary.:)
I've heard that argument before. To be honest by the time you decide that 18 wheeler isn't going to stop you won't have time to move anyway, I doubt the 1/2 second it takes you to slam it into 1st gear will make any difference. But like you point out, everyone's mileage may vary.
Agree with you. I think the Instructor was just trying emphasize the possible benefits of downshifting and remaining in 1st gear at stops. Any benefits resulting from this practice will be purely situational. But when I was a student in Logistics Intern Training, one instructor would always tell us, "Leave Nothing To Chance!" That phrase still guides me in my thoughts and actions daily.:)
To the OP, finding neutral on my trike is not problem for me.
