JW Speaker 8790 nonadaptive headlight install
I've a 2015 Freewheeler. I purchased through JP Cycles a model 8790 nonadaptive JW Speaker LED headlight and installed it today. I've not yet ridden in the dark so I have no idea how the light performs in that situation. I'll try and attach a photo of the face of the light, not installed.
This post is intended to provide information about the light and my installation experience. The lighting unit is of extremely high quality the installation method and final result is not so high quality.
I'll explain the difference between adaptive and nonadaptive technology. Nonadaptive means the light shines straight down the road like any headlight. An adaptive headlight has extra LED's that illuminate the road side as a bike is leaned into a turn. Since a trike does not lean adaptive technology is not required and such a light is useless on a trike, especially considering its $200+ extra cost over a nonadaptive.
The JW Speaker 8790 adaptive and nonadaptive light each use the same housing and face plate so you might think when looking at the nonadaptive; WOW, look at all those LED's. The only LED's that work on the nonadaptive are the center one, low beam and the 3 on the bottom, high beam. Those arrayed in a circle do not work, the LED's and controlling circuitry are not installed.
I've a 2015 Freewheeler that had the factory halogen headlight. This headlight has an H4 (3 prong) connector to the bike circuitry. The JW Speaker 8790 light comes with this same H4 connector installed so it is plug and play. The purchase information on the JW Speaker and JP Cycles site each say an adapter wiring harness is required. This is not true and it is useless. I can speak only for my bike. To verify I suggest you pull your existing headlight loose from its mountings and check if you have an H4 type plug; if so, you do not need the harness. Save yourself $20 to $30.
There were no installation instructions included with the headlight. There was a postcard with a reference link to the JW Speaker site for a video of installation instructions. I found this video not to exist for this specific model light. The installation is a no brainer to a point, the light electrically connects the same as stock and it slips into the housing with the 3 orientating tabs the same as stock but that is where similarity to the stock installation ends. The stock light fits flush to the light housing, the JW Speaker light does not.
There are some bosses on the light that keep it from fitting close to the stock housing by approximately 1/8 of an inch. There is a 7 inch rubber "O" ring included with the light. Having no installation instructions I assumed this installs around the light to seal the 1/8 inch gap and is intended to pinch between the stock housing and the light retaining ring for a water resistant seal, it does no for several reasons. The "O" ring rides too high where the light orientation bosses are and falls into the gap where they are not so there it does not pinch with the light retaining ring leaving a water leak point. Knowing this now I think a thin smear of silicone caulk on the factory mounting face might hold this "O" ring in position to get the pinch seal with the light retaining ring.
Why did I buy this particular light? I bought it for two reasons, the dual burn technology which is when the high beam is on the low beam is also on. The other is, I looked at the JW Speaker site for the light pattern of this light and on low beam it throws light wider to the side and closer to the bike, hence giving me good side lighting but it also throws low beam lighting down the road the same as other low beam lighting does.
Oil pressure light came on again today and stayed on HMMMMMM
I replaced the oil switch a while back according to the P/N on the scan. However this is NOT the correct part number, the correct number is 71400112, made in the USA. No more oil light staying on:clapping: HD had a run of bad switches. The new one is date coded 12/19 2019
That would get my attention in a heart beat wow! Glad you got it swapped out. Ride safe Fred
Yesterday,my riding buddy and I packed our lunches and rode up to Sebring,FL. to the race track and airport. Of course track was closed,but airport was open.Saw a bunch of neat planes parked there. The airport terminal itself was in immaculate condition for being built in 1941. It was a great 200 mile ride except for the Love Bugs we encountered on the way back.Spent a hour when I got home wiping the smelly carcasses off.
I got a nice 50 mile ride in, stopped and got my lunch in beautiful 80° sunny weather.
It's amazing to me how when you have not ridden in awhile, you get on the Freewheeler & head down the highway & it's like meeting up with an old friend & it just puts a smile on your face.
I checked tire & shock psi. I am running 35 psi in the OEM front Dunlop & 23 in the rear Dunlops.
I tried 15psi in the rear shocks, down from 18 & it's perfect on the highway.
I also did an electrical check & everything was good. My baby was running great & the marine Stabil I used did a great job with the gas, keeping it fresh.
My OEM battery is also holding up well at 3 years old. I had planned on replacing it, but as long as it's testing well, I'm gonna let it go. Thanks for listening. :cool:
Warmer weather brought out quite a few people and motorcycles. There was not a lot of social distancing going on in Grafton. Kind of scary thoughts after the excitement of the day has passed.
  • Thanks
Reactions: MDO
We have a Mobil Mart that attracts lots of rocketeers on weekends. There is no such thing as the 6’ rule there , other than most ware face masks 🎭 - Somtimes !
  • Like
Reactions: MDO
A little on the cool side, but I rode to Doc’s to pick up parts for the heritage.
I haven't been to Doc's since I met you there during the bike show... I know Gateway HD is closed on the inside & everything is by appointment.
I ordered my gas/battery gauge.:cool:
My gas/battery voltage gauge is scheduled to be delivered tomorrow.
Glad you got out. I saw you were having warm weather. Ours has stunk with mid 30's in the morning & high of 60. It's supposed to rain Tuesday night thru Sunday.
Bet you were looking forward to Spring. I hope you get some riding time soon, it is the best therapy ;)
I think I'm in Florida Jack. It's supposed to warm up later in the week, but we have rain forecast for the next 5 days. I got my Kuryakyn gauge and the quality looks great, as has everything I've gotten from them.
The harness is pre-wired & they give you a new plug, so I can take the easy way out & cut the old plug off & remove the stock gauge. Their instructions are top notch too with detailed steps & colored pictures.
I will post a pic after installation. :)
That is a cool looking gauge set up, Kury products have come a long way. I remember when they first debuted their products in Sturgis. Their line of products was small and close copies of others. Glad to see they are doing good and have cutting edge goodies;)
If you come to Florida we will ride to The Keys;)
  • Like
Reactions: MDO
New windshield plastic
I replaced my Freewheeler's stock 16 inch windshield plastic with a Clearview shields plastic. The Clearview I got is their 2 1/2 inch wider than stock and 17 1/2 inch height with recurve. I got a clear windshield.
I get much less wind on my chest and buffeting on my helmet. This relieves stress on my arms with less chest wind. My line of site is over the top 1 inch of the Clearview shield. I notice at interstate speeds much less sensitivity in the steering meaning the bike does not tend to shoot into the next lane with the slightest turn on the handle bars.
I finally made my way to the garage to visit my FW. I am hearing rumors it may actually stop raining here in STL next week.
I installed my new Kuryakyn LED fuel/voltage gauge & it was a very easy job & I like the finished product. The mechanical OEM fuel gauge was useless on my FW. I dont have much in the tank (2 gallons), but the last LED on the fuel gauge is supposed to flash red with 1 gallon left, and you can program it if it's off. I really like having the DC voltage gauge.:cool:
There is also an automatic sensor to adjust the LED's at night.
Rotated it......Very Nice!
Ron A
