Motor Trike not reputable IMO
Jun 14, 2017
157
113
Asheville, NC
Ron
Long story short: Only after 8,000 miles (of my 50,000 mile warranty), my tech. ( who installed the kit), says I have to replace the chain, front and rear sprockets, AND, he called Motor Trike who said it was wear parts AND THEY WOULD NOT REPLACE UNDER WARRANTY ! REALLY ! Only after 8,000 miles....I learned a very expensive lesson, that I may turn over to my attorney.
I am confused (what else is new). I have a 2017 GL1800 w/MT Adventure kit. It does not have a chain and/or sprockets. Is it a different motorcycle?
Yes, this is a Honda SilverWing...automatic belt driven..MT came out with a kit for it a few years ago that uses a chain drive from belt hook up
Sorry to hear about your chain problems. Chains have always been a wear and tear item on motorcycle. Roller chains need adjusting often and lubrication. If they aren't properly adjusted they will wear sprockets and chain quickly.
I would look at the Tech who installed you kit. They would be the one who should verify the proper tension was set. But in the end the rider should check chain tension regularly.
I DID check chain and cleaned and lubed every third fill up. I just had my trike on last week for front tire and brakes, air filter and plugs. Chain looked at, all ( Supposedly) was ok !
Sorry to hear of your premature chain/sprockets wear Pastor. There is no real # of miles a chain/sprocket set will run before replacement is needed, as there are too many factors that can contribute to early wear. Something caused your set to wear faster than normal. That "something" could be difficult if not impossible to determine at this point, however.
As said above already, these are considered "wear" items by 99.9% of manufacturers.
If they indeed need replacement, you'll have to bite the bullet and replace them.
If it were me in your situation I'd now look at a good/quality chain maker, (Diamond, or Tsubaki comes to mind), and spring for their top of the line o-ring chain. Going cheap will get you by for awhile, but for long term happiness, quality overrides economy when it comes to chain life in my opinion.
Additionally, correct installation/alignment/chain tension are three critical components that must all be right in order to get max life from the new chain/sprockets you need.
Some o-ring chains require very little lubrication but cannot be run dry or failure could occur, perhaps prematurely, again.
Good luck going forward but I wouldn't waste my $$ on attorney fees for this issue, if I were you...
I understand about the possible wear issues, however, to install this kit Motor Trike only allows those who have been through their training course to install. I used a Honda dealer who puts trikes together everyday. I was just in their shop last week and have in the past asked them to check chain....what else can I do short of driving to Shelby to another dealer?
yrs ago had a gs 750 and the chain was pretty well gone at 16k replaced it with a non oring chain all they had .. i was in omaha in the middle of an 8k mile trip,,, and at 4k it was worse than the original
point is there is a big difference in chain..
when u get your new chain i would check the alignment side to side an twist as well at the tension... if there was a little mismatch some where along the way chain would wear quicker
I will do just that, Thank you.
I was just in contact with Motor Trike receptionist (who I called yesterday for info), the reply she received from their Tech. 8,000 miles is a NORMAL WEAR ISSUE ! Wow, I hate to let the trike go, but, with this as a reoccurring issue every 8,000 miles. Trike will be for sale ASAP
I received info from another forum site, that a Burgman 650 owner had the exact same problem at 8,000 miles, and SHE NEVER used kerosene on her chain!
Thats how i always cleaned chains, [Kerosene]......I even use it to unbind chain saw blades......And it is important to lube any medal that was cleaned with kerosene or it will immediately rust.....
That is EXACTLY how and When I cleaned my chain. This problem (turns out) is a manufacturer flaw that occurs( most likely) every 8,000miles.
Highly unlikely the sprockets are anything other than steel .
Look carefully at both sprockets , look for any teeth that have a sharp edge or a sign of more wear on one side than the other. Check the spacing on the teeth and the depth of the teeth at their lowest point.
I suspect the sprockets are not aligned properly. This will cause very rapid wear of both the chain and the sprockets. A clear sign is a hook at the top of the teeth. Is the chain binding at it's loosest point or at it's tightest point ?
Normally at the loosest point on a two wheeled bike the chain flex is about 1/2 to maybe 3/4 inch.
Modern chains are sealed units that have internal lubrication at each link. Cleaning them really only removes the outer crud, check with the chain manufacturer about what type of solvents they recommend.
How best to align the sprockets should be addressed by the trike maker/installer.
I know how to do it on a motorcycle , but not on a trike ,Yet.
Chains do stretch .....So they do need routine adjustments....With my ATC's ATV's when i would run out of adjustments.....[Now i wouldn't do this with a street bike.]..But i would knock a link out of the chain to shorten it...
My Triumps had steel transmission sprockets and aluminum larger rear sprockets, My Norton was steel at each end. Used roller chain and often pulled chain off with old one to leave in place to pull good one back on weith, thourough cleaning in kerosene, then I'd hang it by a wire, slather Marfak grease on it and heat with a propane torch just enough to see Marfak drawn into rollers & links at pins … let cool and reinstall and adjust.
Later years, when it got harder to find Marfak, I used spray on chain wax which was applied to warm chain. Was easier to apply on bike after warm up ride, but still pulled chain off for good cleaning.
Now, they use O-ring chains that are fatter and can chew into trans housing in places, but there is no cleaning, just use lube meant for O-ring chain I'm told.
Thank you all for your comments, I will definitely check old parts to check wear and or breakage.
Please keep us informed as you progress through this project. I see from your home page (( or what ever it's called) that you are in Ashville, NC . I'm a couple hours east of you in Lewisville, NC. maybe we can arrange to meet up and I could look at your machine. Sounds interesting , what ever the problem is.
Get in touch
Douglas, Donna and I will be out your way tomorrow 4/24/19; if you want to meet up and look at my GT3 and/or old parts give me a call at H- 828-367-2142 or cell 828-275-0215. Thanks, Ron
It turns out when all is said and done, the combination of cleaning with kerosene and lubing with teflon lube, was the worst thing I could have done. It caused premature wear of chain, which caused premature wear of front sprocket. THIS WAS MY FAULT NOT MOTOR TRIKE. Some (so CALLED experts on YouTube), advised this was a good thing to do, in MY case. It was not. I learned a very valuable (and expensive) lesson.
Pmdurant1966
