Rebel RT
RebelRouser
Rear Tire will change to General G-Max RS 245-40-18 which reads 25.7" highx9.8" wide, so instead of 22" high, now will be 25.7" high.General Tire-245-40-18GmaxRs.jpgBut then again I'm still in mockup...:gah:
RebelRouser
Mock-up rear frame & coil-over... HPIM4992.JPGHPIM4993.jpgMoog-k700517 rear bellcrank.jpgBell crank? I love that MT 245x40x18, The tread design makes WOOOOOW!MT 26x10x18.pngTrike Porn...:D
RebelRouser
HPIM4997.JPGSo glad I did this mock up, :clapping:Now I get a better feel for the cross piece, And the jack shaft will go in here somewhere? Next will be the dual coil overs on the front steering support to the control arms...Somebody is NOT remembering the location of jack-shaft? seat?
RebelRouser
HPIM5000.JPGHPIM5001.jpgShock to the right and jack shaft to the left, :gah:MAYBE the seat will clear? Front side view will look something like this? IF I do a fiberglass nose piece, It will be with air inlet in mind. The next M/C swap meet will be July 29, will be thinking hard and heavy about the Harley rear rim??? $300. :( Tire $250. BUT it will look sooooo cool...
RebelRouser
HELP! Does anyone have any leads to part numbers for this style bell cranks (2)? DRZ400-Bell_crank-super7thheaven.co.uk.jpgI am thinking like local NAPA auto store? And while we're at it, jackshaft sprockets, I am thinking using 2 the same size as the engine sprocket?
Bellcrank probably application specific. In other words, do you know what motorcycle it came off of? You will probably have better luck visiting a motorcycle salvage yard for identifying and locating a matching part.
Chains and sprockets. Your local bearing / industrial supply store will probably be able to help you. Just take your existing motor sprocket in and they can probably spec you some new parts.
RebelRouser
HPIM5010.JPGHPIM5012.jpgMore playing with shock locations, and I'm thinking of making my own bell cranks...
RebelRouser
More playing... HPIM5020.jpgMaybe the shocks should be higher yet and maybe I will build a fiberglass nose around them? 1-RT Front.jpgOK, will start dimensions for the upper control arm brace/frame...:clapping:
RebelRouser
Gotta love my local (Long Beach Ca.) motorcycle swap meet every month, just scored a rear rim with mounts for disc and sprocket, 18x10w.HPIM5077.JPGHPIM5079.JPGHPIM5082.jpg
RebelRouser
Hoping to get the lower frame welded this week. HPIM5083.JPGI really do not like the offset of the tire and swing arm.
RebelRouser
Can't make up my damn mind, shocks???HPIM5110.jpgAnd I want them adjustable...
RebelRouser
OK, Feeling not to good about the welders not wanting to hold flatness, sooooo! I redesigned the lower frame to eliminate the 45 degrees (6 pieces) now it is one piece, wider for the suspension but that's OK. Can you believe the hardest part is cutting the 45 degree gussets for the control arms, DAMN cheap Harbor Freight chop saw...
RebelRouser-steering
Rack and Pinion center steer, any opinions? backlash? or stick to my go-cart style? Rack and Pinion center steer-Dan's 8inch.jpg Rack and Pinion-center steer.jpg
RebelRouser
Lower frame tacked welded, now to fit and then tack the mid frame and bring the swing arm into play...HPIM5692.JPG
RebelRouser
Now is the time to mock up the 2 sets of frame rails for the swing arm and looking at sprocket (Harley) clearance and what about the jack shaft? 2 sprockets Harley and Honda?View attachment 62609Does anyone have any input for jack shafts?jackshaft-ijn.jpg
RebelRouser
Rack and Pinion center steer, any opinions? backlash? or stick to my go-cart style? View attachment 62194 View attachment 62195
Stiletto Fast Ratio Small Box Rack and PinionThe ultra fast action of this rack-n-pinion is designed for small oval track or mini baja applications. Precision machined from high strength steel and billet aluminum. Close tolerance manufacturing processes have been incorporated in these units, resulting in a very smooth action, with near zero backlash.
For rear steer applications (steering arm relative to steering axis), mount in the position as shown. This unit may also be mounted inverted, for front steer applications. Considered to be one of the finest rack-n-pinions on the market, proudly made in the USA.
  • 7/8 Total Pinion Rotation
  • 4-1/2 in. Total Rack Travel
  • 11-1/4 in. Length
  • 5/8-36 Splined Coupler (Included)
  • 2.74 lbs.
RebelRouser
Tack welded frame rails, need fixture for alignment of 18 degree uprights, and aligning swing arm...HPIM5744.JPG
RebelRouser
I am in the process of making fixtures to keep the upper and lower rails square so I can weld the 18 degree uprights that tie them together and the swing arm/rim that is giving me fits...HPIM5747.JPGI emailed my Harley source of my problem so I will see him Oct. 28 at the LB motorcycle swap meet...
RebelRouser
Fixtures are welded and trial fit in place, should have taken photo of fixture by themselves, next time...HPIM5772.JPGHPIM5773.JPGHPIM5780.JPG
Dan2003
